lol, no bueno.... still sputters
Sputter at idle
Follow up for those that find my thread during a search.
I replaced my 3.5" HFM/MAF with another 3.5" and that fixed the sputter.Originally posted by blunttechAlways Always go for the reach around if there is an optionComment
Hooray for Solutions
First - thanks so much giantkeeper, for actually posting your solution. So often these are left open (like my other thread currently is) and we never know.
Second - I am having this exact same sputter/miss, cold and warm, at idle, and up to 2500 rpm. I have good compression (between 170 and 180) and I have also:
- Replaced coils, plugs, boots
- Swapped injectors with a second set
- Cleaned ICV
- Cleaned MAF
- Tested for Vac Leaks
- Checked O2 sensor (with car running on GT-1)
Only thing left (well, not ONLY, but let's hope) is the MAF.
I am swapping that out for a known good MAF this weekend, and will post back and see if this was my issue too.
I hope it is - this is the only thing standing between me and a Cali BAR-legal swap! (I fail at idle, likely because of the misfire, which pushes HC up too high).
Thanks again for posting a follow-up that was easily searchable!Current:
1991 325i Sedan - S50 Swap
1988 325i Cabrio
Past:
1991 M3
1991 318is
1985 325eComment
Thanks, I wish I could say it solved the issue completely. It is still there, just far less prevalent.
Good luck, and by all means please post your findings in this thread!Originally posted by blunttechAlways Always go for the reach around if there is an optionComment
I am going with static vanos timing.
Check your fuel pressure at idle.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Injectors/Plugs
Just to close this out - I finally fixed my problem with rebuilt injectors, and a fresh set of plugs.
The plugs alone helped (single electrode copper autolite - not OEM, but aggressive) but it was after the ECU adapted to the new injectors (about 100 miles of driving in my case) that the car stopped missing at idle.
Went from 207 HCs at idle down to 20. I clearly had a big miss.Current:
1988 325i Cabrio
Past:
1991 M3
1991 318is
1985 325eComment
Nice, looks like I'll send mine out and get them cleaned.Originally posted by blunttechAlways Always go for the reach around if there is an optionComment
