getrag 260 whines with m50b28?
  • yazansoft
    • Jun 2011
    • 22
    swapped my gearbox from getrag 220 to Getrag 260 but the gearbox whines on 1 , 2 and little in the 3rd
    the gearbox in good condition and Was working well on the M20B25 before the swap?
  • e46s54dr
    • May 2008
    • 1059
    Have you tried draining and refilling the transmission with new gear oil? Take a look at the old oil and itll tell you alot about whats goin on with the tranny.
    • unloadedak
      • 1197
      if your motor came from an auto car did you put a pilot bearing in it?? that was my problem and killed my first 260.
      2003.5 Imolarot M3: daily
      1995 Alpinweiß M3: hpde
      • yazansoft
        • Jun 2011
        • 22
        i refilled the gear with new oil (90w) but there is Notes in the gear (ATF only) but im using (MTF) ?
        the pilot bearing brand new (M20 one)
        • asubimmer
          • 6482
          I have always run mtf in the cases that call for atf with no problems. Most reputable shops will tell you the same thing...
