I am in the process of an M50 swap and I have decided on the Euro E21 323i flywheel. My car is an 1987 325es, and I will be using the Getrag 260 out of it. I have researched, and i know I will need to use M20 flywheel bolts, it will clear the E34 oil pan, and I will use the M20 starter, but I can't find a definitive answer on what clutch to use. I will be using a Sachs clutch, but I'm not sure which one. I know that since I am going from a daul-mass flywheel with a solid hub clutch to a single-mass flywheel, I will need a sprung hub clutch, so basically a clutch from another single mass car. Bavauto sells 3 kits:
1986-1992 325i
1984-1986 325e
1987-1992 E30 M3
I think the 84-86 325e clutch is what I need, but I have seen people say that they used late model 325i clutches and M3 clutches. If somebody knows which clutch I need, or even better, if somebody has used one of these clutches with a 323 flywheel and a Getrag 260, I would very much appreciate the assistance.
1986-1992 325i
1984-1986 325e
1987-1992 E30 M3
