s52 internals in an m52 Alloy block?
  • mr2peak
    • 2388
    Is this a possible way to create an alloy block s52?
    Drive it hard. Maintain it well.
    A Topless Memorandum
  • Philo
    Ich esse kleine Kinder
    • 3334
    Yep.
    -tim
    Originally posted by Jordan
    I like the stance
    • jrdeamicis
      • Nov 2008
      • 956
      I would imagine new sleeves are required.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • 328ijunkie
        • May 2007
        • 3961
        When you say S52 internals what you mean? You could use the S52 crank for more stroke but the bigger pistons would require a resleeve
        Check Us out on Facebook
        Full Product Line Tuning
        • Myster-E
          Performance
          • 552
          You can use the s52 rotating assembly and just bore and hone the block to size. You do not need to resleeve the block. However the aluminum blocks thread holes for the head strip so you would have to timesert the block which isnt cheap and the weight difference doesnt seem to be worth it.
          1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
          Visit www.BimmerHeads.com for all of your 12 valve needs!
          • 328ijunkie
            • May 2007
            • 3961
            IIRC the Alum M52 (NON TU) is sleeved.
            • psyber_0ptix
              • 904
              do you know what the actual weight savings would be? or are you asking for another reason.
              Originally posted by FredK
              However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
              My year in Germany
              Feedback
              • Wanganstyle
                • 2828
                I have not weighted them myself, but have carried a naked ALU shorty and a naked steel deck, the alu is ~40 lbs lighter feeling, a scale would show the truth.
                • psyber_0ptix
                  • 904
                  I guess if you have the parts already to assemble, cool. But all that work to save 40 pounds...i'd look into brakes first. I'd definitely follow the build with interest. There's tons of Alu blocks in germany....but alas, expensive to ship.
                  Cool!
                  My year in Germany
                  Feedback
                  • mr2peak
                    • 2388
                    There's a ton of iron in an s52 block. And 40lbs off the nose is a lot, that's the same as getting a fiberglass hood and loosing air conditioning and power steering.
                    So would you have to get custom pistons or could you just run the s52 crank and rods with the m52 pistons?
                    • Wanganstyle
                      • 2828
                      bore of S52 is biGGOR.
                      if you want small bore to fit the existing ALU block, the trick is M54b30 rotating assembly for 3000cc result. its a small bore s52.
                      40 lbs on or off nose is ok, just think about the weight and weird bias adding a turbo+FMIC+oil cooler adds!!
                      • hoveringuy
                        • Dec 2005
                        • 2752
                        M52 alloy block with S52 internals is what we call an M54.
