For my E36 rack with the M50, I used the stock E30 lines from the fluid reservoir down to the rack, just shortened them and replaced the clips with hose clamps. For the line from the pump to the rack, I used the E36 line from a junkyard car. Took some creativeness to get it to fit in there correctly, but it did fit, without any bending.
Power Steering
can you snap a quick picture so i can see what it looks like and compare it to mine? i also know that there is a thread on here about remaking new power steering lines for custom fitment but i cant seem to find it right now. i'll keep looking.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
^^yeah same here regarding the e36 line. i basically had to make sure the metal portion of the hose, on the pump side, wasn't touching anything. I held it in the right position as a tightened the banjo bolt. the bent metal portion looks kind of funny the way it is sitting but it gets the job done.For my E36 rack with the M50, I used the stock E30 lines from the fluid reservoir down to the rack, just shortened them and replaced the clips with hose clamps. For the line from the pump to the rack, I used the E36 line from a junkyard car. Took some creativeness to get it to fit in there correctly, but it did fit, without any bending.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
