OBD2 Cam position sensor?
  • MattM
    • Apr 2009
    • 931
    96 328i M52 engine, mine is toast. I have a spare one from a 93 M50 sitting here. Will it work? or do i need to buy another one?
    Full Build Thread Here
  • sticksdaman
    • Apr 2005
    • 2987
    you running obd1? if so then as long as the plugs match (cam sensor female,harness male) I dont see why it wouldnt.
    Assuming both motors have Vanos
    Originally posted by ebelements
    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
    • MattM
      • Apr 2009
      • 931
      no, im running obd2, sorry i didnt make that clear
      • sticksdaman
        • Apr 2005
        • 2987
        In that case it wont work, the obd2 cam sensor harness side plug is female and so is the obd1 cam sensor plug.
        I've learned this the hard way.
        I actually have a brand new obd2 cam position sensor. idk if you want to pay the shipping though. LMK
        • MattM
          • Apr 2009
          • 931
          it plugs into the harness fine and fits into the head fine, but the tip of them look different. one is magnetic and has a metal cylinder on the end(obd1?) and the old one is just a black plastic thing, and is not magnetic...
          pm me a price on that sensor..
            • 34844
            Obd1 is a hall sensor, obd2 is something else entirely
            • drumad
              • Aug 2009
              • 1700
              I have one as well if the other guy doesnt work out.
              2008 335i - n54b30
              1991 318i - m52b28
              1994 fzj80 - LAND CRUSHER
              • MattM
                • Apr 2009
                • 931
                yes, this is what i thought, just couldnt remember what it was called..
                • jrdeamicis
                  • Nov 2008
                  • 956
                  Your OBD2 cam sensor is a CID sensor (Cylinder Identification Sensor) Neither a hall or VR. Its a 103k Waveform that becomes modulated to a different amplitude in the presence of the trigger wheel.
                  FIRST!
                  Don't use any aftermarket sensors - no Meyle or any other brand
                  Second
                  Only buy BMW
                  Third
                  Only buy new to replace
                  OBD2 uses resistance to check the sensor also. Code P0340, and the sensors are very sensitive. A lot of people have had them die just from removing them.
                  Best of luck.
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
                    • 34844
                    I have a brand new in box obdII sensor if you want it. I can even have it shipped from Canada.
