How much would an M50 swap cost?
  • AsharC
    • Jun 2011
    • 1508
    As the title states, how much would it be to swap the car? How much did you guys pay for any swap in general? I am interested in M50 or an S5x swap. Any info is helpful
    Thanks
    BUY MY WHEELS! BBS E50s!!
    http://www.r3vlimited.com/board/showthread.php?t=275407
    Originally posted by Lurker27
    Any man will tell you being blown is better than being stroked.
    • 37829
    $20,000-$30,000.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • samiam3356
      • Jul 2009
      • 1901
      30-40,000 if you want that omgthatlookssofactoryfresh look. Ya know?
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • Nick325is
        • 1409
        I'm about 35,000 into mine and I still need more Powa!
        • mcgillaguddy
          • 487
          I have about $1200.00 into my m50 swap. But I did get $400 back from selling my m20 and the getrag 250 that came with my m50.. I did all the work myself though... hope that helps...
          1988 M6 - The real project.
          1993 325i Vert - Project/Weekender
          2013 ATS 2.0T - DD
          1997 740i - sold
          1987 325is Turbo -sold
          1991 325ix - Sold
          1990 m50 325is - sold
          1987 535is - sold
          • e30e
            • Dec 2004
            • 2176
            Depends on how many new parts you buy, how long you want the swap to take, and how much beer you drink.
            1985 BMW 325e
            1997 BMW M3/4/5
            2007 Chevy Silverado Crew Cab 5.3 v8
            • MattM
              • Apr 2009
              • 931
              a do it yourself tossed together m50 can be done for less then $1500.
              a do it yourself fresh, clean, and reliable M50 swap can be done for $3000
              a do it yourself clean and reliable S50/S52 can be done for $5-6000
              A fuck this i want someone else to do it... Add 20-30k on top.
              Full Build Thread Here
              • Ayman
                • Apr 2011
                • 4190
                they're just pulling your leg lulz.
                $20-30.
                Originally posted by yert315
                Your mother is plug n play
                • jrdeamicis
                  • Nov 2008
                  • 956
                  Labor is generally $1500-2k up to 3k.
                  Budget 5k. And you can have a nice swap.
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
                  • devon.818
                    • Feb 2011
                    • 2937
                    ill4noreason did his for free....he bought a e30 that was swapped, took the drivetrain, parrted the rest and actually MADE money. now that is the way to go
                    m50~5-800
                    all the accesories~5-600
                    random things you forget~200
                    so about 1500ish should be good, then you can sell your m20 and old trans, hopefully trade someone diffs and come in closer to 1100 when all said and done.
                    • cmybimmer
                      • 894
                      Originally posted by MR 325
                      $20,000-$30,000.
                      • e30rapidic
                        • 2167
                        best thing to do is find a friend to help you out that has already done it!
                        '87 325ic, powered by S50.
                        • scottinAZ
                          • Dec 2009
                          • 1312
                          right now parts only, Im about 2800 into it
                          1100 motor, harness and accessories
                          100 clutch and flywheel
                          125 radiator
                          55 DME
                          135 oil pan, dipstick
                          200 trans, shifter and driveshaft
                          250 misc core charges (refundable)
                          6-800 new maintenance parts (belts, hoses, center support, shift carrier rebuild,water pump, all new gaskets, shit like that)
                          Keep in mind that I am also doing a 5 speed refit at the same time, so about 4-500 of the cost can be saved (easy) by already having the transmission of your choice, along with the appropriate driveshaft
                          It can most likely be done a LOT cheaper, but I dont want to have to go back into this thing for a while and redo something I could have done correctly the first time
                          in the end, I should have a reliable DD
                          I saved 15% on my Bimmer parts by switching to ...
                          • AsharC
                            • Jun 2011
                            • 1508
                            Thanks for all the help. I will look into a swap a little more.
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              $600-$10,000. It all depends on the deals you get, if you do your own labor, and what parts you replace with new ones.
