I know this has been asked/coved before, its just there is so much in put on this matter so i will like to hear from the people who actually done wat it is i'm asking so sorry in advance.. I just picked up a s52, and all the obd1 stuff out of a 95 325is sensors, Manifold(intake only) ecu.
Subject ?#1. Is this the rite drama free ECU and is this all I need for the obd1 conversion? (ecu,harness,afm,o2 sensor,crank sensor knock sensor. Do i need the coil packs as well or can I use the stock S52's? will this ecu need software? Picture of ecu below.
Subject ?#2. Brake Booster.. Slot the holes or run the 320? I think its better to move mine over, some folks seem to not think of that as a good idea.
Subject ?#3. Exhaust Manifold.. I have the stock S52 headers with the factory cats and resonators.. Will this work fine with a little modding or is there a smipler way?
Subject ?#4I want to use my g260/stock Transmission. Ive read you have to shave the 525 oil pan then some say you dont. Ive also read stock M20 FW bumps into the block, in hence needing to be shaved. I have acess to the S52 trans, but can I use stock drive shaft? should I use Trans,drive shaft (if it fits), is this the better route? Again everyone I read and read up on this/i have researched this.. it just seems
to me? Any help will be greatly appreciated.. again THANKS in advance;). PM me as well, with any help!
