M50 sensors
    M50 sensors
    Hello,
    My swap is almost at the end but I need to figure out what sensors go where. I can get the colors of the wires but is there any way to look this up in the ETM? The only way I would know how is page by page looking at every wire, but there has to be an easier way. I find the ETM a bit confusing and I'm not really sure how to navigate through it to find the information I want.
    Help greatly appreciated,
    Aaron
    r3vlimited Lanyard Group Buy!!!
    Find the pin out of the dme and run a continuity test on the connectors. Way faster imo
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
      I assume the DME pinout is in the ETM somewhere?
        I followed the colors of the wires and matched them to the ETM.
        COTM
          From the swap wiki, and also what I used on mine.
          oil pressure sensor BRN/GRN or BRN/GRY
          front coolant temperature sensor (ECU) BRN/RED BRN
          rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
          crank position sensor YEL
          cam position sensor YEL RED/WHT BRN/ORG
          VANOS solenoid RED/WHT GRN/BLU
          knock sensor, 1-3 BLK NCA DME PIN 70 (actually numbered on the wiring sleeve)
          knock sensor, 4-6 BLK NCA DME PIN 69 (actually numbered on the wiring sleeve)
          throttle position sensor (TPS) BRN BRN/BLK RED/YEL
          intake air temperature (IAT) sensor BRN GRY
          idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
          Evaporative emissions valve BRN RED/WHT
          Always Always go for the reach around if there is an option
            Awesome! I missed that on the swap wiki, thanks giantkeper
              yessir, you bet :up:
