I know I have seen some good pictures of how people did them but I can't find them now. I could just wing it but it would be nice to see if anyone had some tried and tested cutouts they did. :woowoo:
Where to trim M3 harness cover?
I took off about an inch right above where it contacts the intake manifold, if you put it up where it goes, you can tell where you need to trim it. I'd give you more info, but it's kind of hard to see installed, and I am NOT taking those things back off.
Be VERY careful cutting that plastic, it's extremely brittle and will crack if you cut it wrong. I'd use a Dremel. -
Mine seemed like it was too tall. Didn't spend to much time on it though. Still need to get mine on as well.
Originally posted by Roysneon$5 shipped?Originally posted by MarkDYou are a strange dude, I'n not answering any more posts from you.Comment
I used a dremel on mine. I cut two upside down "v" shapes where it was hitting the manifold. Pretty simple when you've got it all in front of you.
S50'd
Originally posted by TDE30What is this faggy shit I have happened upon?Originally posted by slammin.e28I can always live in a M3. Can't M3 a house.Comment
Take a look at my post. It's half way down.
its probably different for every car. there are 2 different types of manifolds, depends on brake booster size, where you locate the bracket the cover snaps on, etc. I would trim to fit your car once everything is in place.'87 325ic, powered by S50.Comment
Like this ;)
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Dave is it going in between the weather stripping?
The end piece (battery tray) is supposed to, yes
