Hey guys, I've been working on this swap for a while now but It's not looking too good.
At first when I started the engine it would come on and idle great and stay at 8k but I never let it run for more than 10seconds at a time since I don't have a puller fan.
When I finally got the balls to start it and give it a rev it would bog down as if it weren't getting fuel but then it would go up to about 3k and rev fine and then it cuts as if you turned the car off and then revs back up to 3k and cuts again.
I installed a Y-pipe to hook up my o2 sensor and still nothing. I disconnected the Throttle Position Sensor and played with it while running but the engine acted as if it weren't even there. it also runs the same without it plugged in at all
here's a quick vid
Someone help please.
Thanks cheers!
here's a quick vid
Thanks cheers!
