I just searched online and couldnt find much. I saw on diagrams pin14 for both harnesses as you said.
My question is, I can still have a functioning speedometer as the signal is from the sensor in the diff, but at the same time have a bad connection between pin14 on c101 and x20?
I also forgot to mention the PO wired the car incorrectly, and my friend had to get the diagnostic port to work as I was getting a 1281 code, but no stuck with a recurring 1234
Try driving it around easy for about 30mins/miles after resetting it. IIRC that's how mine went away. I think the ecu just has to get used to the new signals
the signals are exactly the same. both the E30 and E36 use a 9-tooth diff/speedo sensor.
sounds like quite the mess of a harness, speed signal hooked up to O2 sensor? obviously the PO didnt bother to crack an ETM and just went on some random pin to ping diagram, which obviously wasn't the right/good one.
