Can OBDII coils and ignition harness be used with OBDI
  • e30gentry
    • 608
    Can the OBDII coils and harness be used on an OBDI swap?
  • hoveringuy
    • Dec 2005
    • 2744
    Yes. I'm running them like that.
    • Leo_328i
      • 226
      Absolutely correct.
      Only difference is that the OBD1 ones seem a bit larger and heavier and have 4 bolt holes instead of 2. Otherwise they operate exactly the same and are plug and play interchangeable.
      Fitment isn't perfect but they work good.
      Leo.
      E30 318iS, E36 328i
      • e30gentry
        • 608
        awesome thanks
        • 328ijunkie
          • May 2007
          • 3961
          Coils yes, coil harness no. You use the obd1 coil wiring that's integrated into the harness
          Check Us out on Facebook
          Full Product Line Tuning
          • e30gentry
            • 608
            Even with the OBDII valve cover?
            • Leo_328i
              • 226
              They don't quite fit right but they work if that makes sense.
              You might need to use washers or something to make them fit properly.
              Leo.
              E30 318iS, E36 328i
