Who is the strongest Getrag 220 Vs Getrag 240
  • yazansoft
    • Jun 2011
    • 22
    Who is the strongest Gearbox
    220 from e36 318is euro
    240 from e30 318 euro
    how much horsepower they can handle?
    im using 220 now with m50b28 ind i plan to using 240 to get taller ratio
  • KenC
    King of Kegstands
    • 14396
    The 240 will handle that engine, no problem. They're good for up to 300+ wrhp.
    Originally posted by Gruelius
    • Wh33lhop
      • 11705
      I have seen plenty of 240s behind US S50s and S52s. Never even heard of the 220 before though.
      paint sucks
      • MattM
        • Apr 2009
        • 931
        +1, never heard of the 220.
        Full Build Thread Here
        • Fusion
          • Nov 2009
          • 3659
          They do exist, very little info about them.
          If you can, get the 240, atleast the transmission brace/mounts won't have to be modified in any way. Sits nice and straight.
          • MaxBell
            • 1391
            Yes, but 240 or 260?
            REMEMBER: Be safe and have fun is Rule Number 1.
            The Epic Unbuild of Clint Eastwood
            • Gruelius
              • Oct 2009
              • 298
              im goin for 240 cause my 260 has le getrag rattle
              RIP 84 323i coupe 5spd w/ 14psi
              89' 318i
              • sohc12vm20
                • Jan 2010
                • 688
                so a 240 is better than a 260, as far as mounting and not having to make trans bracket wise? Because I have access to a 240, my engine will be going in next week I'm thinking if this is correct just picking up the 240 instead.
                • yazansoft
                  • Jun 2011
                  • 22
                  the getrag 220 come from e36 Europe 318is to 325, its the same as getrag 250 in the us,
                  the Getrag 260 is the best one cane handle horsepower, but i don't know about 220 and 240 hose strongest?
                  i think the 240 need to taller drive shaft than 220 / 250.
                  • KenC
                    King of Kegstands
                    • 14396
                    The 240 can definitely handle a worked M50.
                    • surebimmer
                      • Jan 2004
                      • 978
                      The number (ie 260nm) is the torque rating of the transmission so higher would be stronger.
                      • trackjunkie21
                        • Jan 2010
                        • 3962
                        240 behind my m50. no problems at all.
                        VANOS: sometimes you just need to go full retard.
                        • e30s50dan
                          • Nov 2008
                          • 2076
                          S50 still ponding the crap out of my g240... So far so good
                          NASA
                          BMWCCA member
                          PCA member 25yrs
                          1991 318IS slick top
                          1997 M3 sedan
                          2001 325CI DD
                          “whoever turns the wheel the least, wins"
                          • e30pq
                            • Apr 2006
                            • 579
                            The G240 can handle around 300 hp and 300 ft lbs of torque.
                            If you make more power than that you have a problem. I know this first hand because I blew up 2 of them this year behind a turbo M42 powered E30 club race car. This is a video of the first one we blew.
                            Some background on the car:
                            • Fusion
                              • Nov 2009
                              • 3659
                              I just got done putting my M50 on the green E28M5 engine mounts and OEM E36 engine arms last week. The engine and 240 trans sit perfectly. The OEM trans brace doesn't have to be modified in any way. In neutral, my shifter is exactly straight.
                              Makes me happy. PO made a shitty setup with fab'd motor arms so I had to fix that after trashing the M20 engine mounts on track days.
