e34 pan too low
  • blueapplesoda
    • Dec 2005
    • 1904
    e34 pan too low
    I know taller engine mounts will work here, but the question is clearance on the hood side. What are the tallest engine mounts that I can fit in? its kind of stupid how low this pan sits, and how our pans are right in front of the front "axle"
  • Wanganstyle
    • 2828
    Time to 24v REAR SUMP + E30 :)
    • nomansland92
      • 1657
      ^ I like where this is going ;)
      IX being restored here
      Ix turbo build here
      • 328ijunkie
        • May 2007
        • 3961
        my next cust car will be rear sump.
        Check Us out on Facebook
        Full Product Line Tuning
        • mo diesil
          • Jan 2011
          • 275
          i think a M5 mount is best dont quote me on that
          • Fusion
            • Nov 2009
            • 3659
            Yep E28 M5, installed "wrong". Can lift the header side with a washer or two.
            Can't go much higher because of the trans bell and headers will probably push up against the body.
            The point closest to the hood is the very front of the cam cover. You can test by putting putty on it and closing the hood, then measure putty thickness.
            • jahnaboi
              • Oct 2006
              • 1742
              Newb derek! I never liked the idea of angling the motor to much because of the thrust angle under load.
              That's why they make skidplates son! lol
              SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
              • kalib0y
                • Dec 2004
                • 3620
                I used the green mounts with about 1/4in of shimming and it still cleared my hood and strut bar
                95 7.1L 16V E36 M3
                Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                LIKE my Facebook Page! CLICK HERE
                • Elysian
                  • 674
                  My E24 has the same problem with its frigging stock engine :( the swap won't be any better either.
                  • M-technik-3
                    • 18946
                    Dry Sump solves these type of issues.
                    VAC Motorsports 6 Cylinder Dry Sump Oil System was originally designed for our own race cars. Customers have been running these systems for many many reliable years around the world and have supported many cars to the podium.
                    VAC Dry Sump Kits:
                    completely in house CAD designed and CNC machined
                    Helps to ensure positive lubrication
                    Increased oil system reliability under all conditions
                    Underdrive Hardcoat Anodized pulley system
                    Underdrive pulley features a step on the back to allow installation of aftermarket crank trigger wheels
                    Toothed belt system
                    Peterson Oil Pump an industry leader
                    Click Here for a pictorial break down of components
                    Our Dry Sump Kit Includes the following parts:
                    Peterson 4 Stage Dry Sump Pump
                    Peterson Pump Pulley
                    CV Pump Drive Pulley & Washer & Bolt
                    VAC Motorsports Underdrive Pulley & Adaptor
                    Pump Mounting Bracket with hardware and spacers
                    2 Dry Sump Pump Belts
                    3 -12 Inline Scavenge Filters
                    This BMW 6 Cylinder Dry Sump Kit fits the following engines: M50, M52, M52TU, M54, S50, S50 Euro, S52, S52 Euro, S54.
                    VAC Tech Note: We recommend using our VAC Billet Racing Oil Filer Housing with this kit to facilitate maximum efficiency, ease of service and ease of installation. Find a link below.
                    Expensive option but sometimes it really is not that bad if you waste an engine.
                    • Wanganstyle
                      • 2828
                      Dry sump is not really a street solution; whatever expense it may be-
                      VAC does not release specs on running time of these things for street use do they?
                      Also, where are you going to mount the dry sump oil tank on a street car? Passenger footwell area is great if you don't have a dash/HVAC etc
                      local custom dry sump added to VAC full race S54:
                      passenger footwell has a box that the tank lives in
                      note AN oil feed/output
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        I hear so many stories about people's oil pans sitting too low, what mounts are you guys running?
                        I have IE yellow poly e28 mounts and no clearance issues with h&r sports. I have heard of them melting on the exhaust side though
                        '89 Alpine S52 with goodies
                        • Fusion
                          • Nov 2009
                          • 3659
                          Yes, I'm going to shield and possibly make an air duct to the header side mount, because it gets shitloads of heat and any mount will wear prematurely.
                          And I don't think the pan is that low. I think it's about level with an IS lip. Danger depends on the drop of course.
                          • castros
                            • 828
                            We use factory e46 mounts and the pan will only be about half an inch lower than stock (m20).
                            www.CASTROMOTORSPORT.com
                            Castro Motorsport
                            12600 Sherman Way, Unit C
                            North Hollywood, CA 91605
                            818-765-3606
                            Follow Castro's on Facebook:
                            http://www.facebook.com/pages/Castro...02411516506828
                            Follow Castro's on Instagram:
                            http://instagram.com/castromotorsport#
                            • GunMetalGrey
                              • Dec 2010
                              • 1499
                              You kids and your complaining! Have you ever driven a slammed late model 318? THAT is a low oil pan, feel free to ask me about it.... lol
