Pusher fan stuck
  • Fusion
    • Nov 2009
    • 3659
    Pusher fan stuck
    I found out my pusher is blowing fuses because it doesn't turn freely. I can turn half a turn easily, but half a turn is hard with my hand. Its not scraping anything on the outside.
    Not sure if its stock E30 or from a different model BMW, but it has two speeds.
    What are the internals like in these things? I read something about bearings? Is it fixable or should I start looking for a replacement?
    Driving it was fine, but when I got stuck in traffic, the needle got up to the 3/4 mark and that made me nervous.
  • 328ijunkie
    • May 2007
    • 3961
    Replace it. Motor is dead.
    Check Us out on Facebook
    Full Product Line Tuning
    • Fusion
      • Nov 2009
      • 3659
      Bump.
      I replaced the fan short after that post with a used fat one from an e34. Ran awesome, blew like a mofo.
      Saturday I got the car all shiny and after a quick ride I burnt my finger on the resistor because the fan wasn't spinning. It's stuck again.
      Do these things rust or something? The car wasn't driven all winter.
      • 328ijunkie
        • May 2007
        • 3961
        The resistor will get burning hot no matter what but it may be that your resistor is fried (or resisting too much) does high speed work?
        • Fusion
          • Nov 2009
          • 3659
          Both speeds are dead and it's hard to turn the fan freely by hand.
          • 328ijunkie
            • May 2007
            • 3961
            By a spal and be done with it.
            • Fusion
              • Nov 2009
              • 3659
              Ok I found the sixteen incher I can order, recommend size here on the forums.
              Though I went through some threads, I'm not sur if I can just wire up the old wiring, it was working OK both temp swith and the manual buttons I have inside. Do I still use the old resistor?
