Hey all,
Doing an m50 swap into my early (84' 318i) e30, and I was wondering if anyone could provide some guidance on a couple of things...first being how they mounted their radiator. I have a rad out of a 95' 325i (e36), I'm assuming I need to remove the fan shroud, but I'm not seeing an easy solution for mounting it up to the rad support.
My second question, is about the transmission crossmember, I ordered a full m50 swap from bav auto, and they sent me an e36 325i 4dr cross member (my e30 is a coupe, if this makes a difference) and the cross member does not seem to match up in any way, shape or form. I know the studs slide for adjustment, but there's no way it will line up with any of the holes on the Xmember. Help? (below is a pic of the piece with the mounts installed)
Edit: from what I've been reading on AKG, I guess I can still use my factory trans support with different mounts, anyone else done this?
