FML Seized M50
  • Fusion
    • Nov 2009
    • 3659
    I would rather spend 4 hours fishing through the plug hole than taking the head off because of a nozzle.
    You can try taking an air compressor with one of those cleaning nozzles and blasting air in there on/off and if you're patient, physics says the nozzle should shoot out sooner or later.
    It takes years before pistons stick to the cylinder due to rust. I helped a friend get an engine like that turning. It was in someones yard on the ground for like 3 or 4 years. Even if you got rust from a couple days humidity in there, it would be like the orange stuff on brake rotors, you can wipe it off with your finger.
    • TimKninja
      • 2131
      Sprayed PB blaster into the cylinders . I doubt PB blaster will harm the cylinder walls .
      What's an IIRC?
      1985 325e M50TU(Sold)
      1991 318is Slicktop (Sold)
      1990 325is Brilliantrot S50/5 Lug Swapped.
      1992 525i Manual shitbox Winter Beater
      • scottinAZ
        • Dec 2009
        • 1312
        lack of oil due to pb blaster spraying will however. squirt about a tablespoon of oil into the cylinders to relube the walls, and all will be OK.
        IIRC = If I Remember Correctly
        I saved 15% on my Bimmer parts by switching to ...
        • TimKninja
          • 2131
          Ethier I'll be pulling the engine and tranny or just the tranny tonight. Thanks for the help guys.
          • Vtec?lol
            • Dec 2009
            • 3278
            That sucks, to get it all in there then bam. issues.
            That flywheel is def. binding. No way to use it without shaving, or using an m42 fly spacer
            • Mr.SWISS
              • Nov 2005
              • 1251
              Do yourself a favor and use an E36 trans and front shaft. And don't deal with weird tranny angle and shifter that needs cut and welded.
              Originally posted by 325Projectz
              don't listen to the diagram... listen to mr. swiss.
              :nice:
              • MattM
                • Apr 2009
                • 931
                this, i did this after i found my oil pan gasket wasnt sealing right... needless to say the tranny had to come off with the G260.... swapped to a 35k mile Zf320... much happier
                Full Build Thread Here
                • TimKninja
                  • 2131
                  Is the e34 trans the same ? I have a 5 speed e34 trans with 320k on it.
                  Just got the tranny off in an hour lol. It's DEFINETLY binding. Thanks guys!!!
                  • Pudmunkie
                    • 210
                    I don't know why op keeps saying "some " people have binding issues. In my research it's never been an option, but a necessity
                    Sent from {smartphone;}
                    • TimKninja
                      • 2131
                      My friend doesnt recall having to shave anything down. I was dumb for not checking for binding.
                      Engine is freed and turns smoothly now!!!
                      Pictures of bindage.
                      • Fusion
                        • Nov 2009
                        • 3659
                        No worky.
                        Don't link to your mail account.
