My remote res solution (pics)
  • equate975
    • Jun 2004
    • 3382
    After several trials and errors I finally have a pretty good workable solution.
    We started out with some 1/4 inch stainless steel pipe couplers and machined them to fit in the MC.
    After a lot of playing around I ended up with a braided stainless steel hose that connects the MC to the res.
    First up I got some 1/2 inch brass pipe fittings attached to the res via jb weld the flanges of the plastic pipe fit PERFECTLY and with a dab of jb weld these things are on surprisingly tight.
    That my friends is a faucet line fixture thing, I tested it by running and soaking it in brake fluid and it holds up. The tricky part was to get it to connect to my 1/4 inch coupler.
    I spent 1.5 hours in home depot trying to figure this out, and this was the simple solution
    So these are the hoses connected to the fittings
    There was also a bracket machined to be held down by a zip tie to make sure the fittings dont pop out ever.
    Heres a good shot
    Just for some good safety measure I used some lock tite pipe/everything compound putty to seal the ends, there is an O-ring below the 1/4 coupler that was machined to make it a pretty tight fit in the first place.
    And the finished product
    Parts:
    2x 12" stainless steel faucet connectors, 1/2 pipe thread on one end, 3/8 compressed thread on the other
    2x 3/8 X 1/4 tube with insert MIP connector (mip connector not used)
    2x Machined stainless steel 1/4 inch pipe couplers
    1x bracket
    1x 2" 1/2 inch brass pipe cut to fit
    JB Weld, and Locktite putty
    Rollin' with a Geistkuchen
  • equate975
    • Jun 2004
    • 3382
    Yeah dont worry about the pic with the res on backwards lol
    • Jordan
      • 12916
      Why didnt you use the OEM parts widely available.
      That setup looks ghetto as all hell, and will likely rupture at a innopropriate time. Home faucet parts aren't designed to be enduring brake fluid, let alone borderline boiling brake fluid.
      https://mtechniqueabs.com/
      • AndrewBird
        The Mad Scientist
        • 11898
        Ditto. I agree completely. While bench testing might have showed that the hoses can withstand brake fluid, real life testing I believe will prove that they will not be up to the task.
        • joshh
          • Aug 2004
          • 6195
          You can easily replace those water lines with solid tubing. If you know where your going to put it.
          Your remote idea is great but it needs some refinement.
          Are the fittings going into the res just nipples. If so I would clean the extra jb weld off use some gasket material and use 2 nuts on both sides of the nipple. The brake fluid will expand and contract eventually causing brake failure and I would imagine very quickly.
          "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
          ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
          • equate975
            • Jun 2004
            • 3382
            Yeah, well I have options to play with. I can easily replace the SS lines with brake/clutch lines if i can find them big enough. The jb weld you are reffering to was pipe putty. The fittings that go into the the res have a neoprene o-ring, and with the plate on top it does not leak. I used a pvc type suringe to get as much pressure as I could in it, and it did not leak. I just put the pipe putty on for good measue. I tried gasket sealer but it couldnt keep a strong seal to the aluminum and just worked its way off.
            EDIT: I misunderstood your post, yeah the nipple on the res are held in by jb weld. I tried to pop them off yesterday to get some 90 degree bends in it and.. they WONT come off lol. I can break the jbweld seal if I try hard enough, but they will only move down about 4 mm. I put the nipple in a vice and tried to pull it off, but after about 10 min I decided not to mess with it because I did not want to break the plastic res nipples off again.
            • joshh
              • Aug 2004
              • 6195
              Remove the lines, clean up the JB weld and add a nut with gasket material and teflon tape to the threads. That should make sure the JB weld doesn't expand and contract much.
              • equate975
                • Jun 2004
                • 3382
                I FOUND IT!!!
                Check this guys
                Our PTFE hose has a stainless steel outer braid for operating pressures from 2000 to 3000 psi depending on size. We offer -2 thru -8 sizes for brake, gauge, clutch, or power steering hoses.
                brake hose by the foot :)
                • joshh
                  • Aug 2004
                  • 6195
                  I would have someone do the fittings for you. Like Oil Filter Service of Portland. Thats all they do really.
