Unique e30 m50
  • epluribusunum
    • Feb 2011
    • 5
    Unique e30 m50
    Please check out my E30 M50 build on facebook:
    and also this E30 WILLWOOD PEDAL MOUNT:
    Thank you,
    realm3bimmer@yahoo.com
  • 328ijunkie
    • May 2007
    • 3961
    Youre doing it wrong.
    Check Us out on Facebook
    Full Product Line Tuning
    • Fusion
      • Nov 2009
      • 3659
      Wow. Most complicated M50 swap ever.
      Why did you decide to push the engine a foot back?
      • 328ijunkie
        • May 2007
        • 3961
        Rear sump from the looks of it
        • MattM
          • Apr 2009
          • 931
          i respect the amount of work and fabrication, but have to ask why...
          sure, i get that putting the weight more evenly over all 4 wheels will increase handling, but i cant see a foot being worth that much work....
          Full Build Thread Here
          • Danny
            • 14216
            Japandrew?
            • L8 apexr
              • Dec 2010
              • 226
              Getting that big lump back a foot WILL make a huge difference,its not so much about getting more weight to the rears but more importantly removing weight from ahead of the front wheel centerline.
              Removing/relocating weight from outside the wheelbase has more effect than inside the wheelbase so I say good job.
              Are you moving the seat,controls etc back as far as possible to match?.
              I won a canadian national autox title in a rented corolla race car that had the engine back about a foot,the seat was back further than that and a custom shifter linkage as you wouldn't have been able to reach it.The car turned and put power down very well for a live axle car.
              • mazur
                • Jan 2006
                • 731
                A foot is a lot when we're talking that much weight. Especially when we're moving it in behind the front axle.
                This build is pretty crazy, but most classes probably don't allow for such major modification (I think). What type of racing events are you planning on attending?
                • Wanganstyle
                  • 2828
                  why not just relocate ancilleries to rear of car and power them off the rear axels? i.e.:
                  alternator
                  power steering
                  then fit e36 front x member and run native rear sump? delete both sway bars or add the front e36 unit.
                  that should be a decent amount of weight and much easier to do than shift firewall.
                  some e36's come from the factory more weight % rear than front
