Guess what? Yep. It wont start.
  • dubseven
    • Jul 2011
    • 382
    Swapped cam sensors, no dice. Apparently you cannot OHM the VANOS crank sensors.
    SO. back to square one :( I still STUMPED. Sigh.
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      The backfiring thing is what gets me.
      You tried the "brake cleaner" test yet?
      Not spraying carb cleaner around the engine but rather have someone spray some carb cleaner, WD40, or brake cleaner directly into the intake while you crank the engine.
      If it fires up for a second you have fuel delivery problems.
      • dubseven
        • Jul 2011
        • 382
        99% sure its getting fuel, but I will go try that now. I have tried about everything else there is to try LOL
        • dubseven
          • Jul 2011
          • 382
          OK so who wants to have a good laugh at my expense?
          • Chris916
            • 183
            It sounds like the problem i was having. Turned out I didnt align the Crank wheel on the alignment pin so it was off causing backfiring and sputtering but no start.
            • dubseven
              • Jul 2011
              • 382
              One of my buddies that was helping me grabbed the NON-Vanos crank pulley / trigger wheel. Which is way, way different from the S50 wheel.
              *facepalm*
              Swapped it over... runs like a boss!
              • Mr.SWISS
                • Nov 2005
                • 1251
                Ouch.
                Working solo FTMFW
                Originally posted by 325Projectz
                don't listen to the diagram... listen to mr. swiss.
                :nice:
                • dubseven
                  • Jul 2011
                  • 382
                  Apparently the timing being like 70 degrees off is an issue... LOL!!! Not his fault, he is a DSM guy and a great wrench, just had no idea there was a difference.
                  • Den_k321
                    • 1248
                    This is a very good thread, lots of good ideas and if some one have a problem with start can refer this.... =]
                    1988 325is S50 in-progress.
                    http://www.facebook.com/E30LocalCrew
                    Few pictures:
                    http://www.r3vlimited.com/board/showthread.php?t=255061
                    • Jafxod
                      • May 2011
                      • 1301
                      Lol'd. glad you got her running.
                      Great point.
