Searched desperately for about an hour. No info.
Heres the setup
silver label 413
WAR chip for 413 and 506 ECU
E34 M50 Harness (95)
96 M52
60lb Injectors
Blow through Maf (Miller)
Im not getting a fuel pump signal. Which is obviously EWS or something. I was under the assumption that the WAR chip bypassed it but im not sure.
Ive emailed brody. I must be getting annoying because hes been slow on the responses. Any suggestions?
Question: Will the WAR chip work with the silver label 413 ECU? And does it bypass EWS2? IF so i suppose i have another problem.
Heres the setup
silver label 413
96 M52
60lb Injectors
