i have a 1984 325e and i am doing a swap. i purchased an ix booster and master comes to find out the ix is an abs car and mine is not what do i do. what master cylinder do i need for a non abs. or should i just scratch the ix and slot the firewall.
no brakes :/
why won't your OE lines plug into this?? they should, may have to bend em a bit but plug em just like they were originally.
also, ditch the spacer on the IX booster, cut and thread the rod on the back. you'll thank me later ; |No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5Rs
Originally posted by etxxz View Postwhy won't your OE lines plug into this?? they should, may have to bend em a bit but plug em just like they were originally.
my master has the line coming off of it the master for the ix only has two. what is the benefit of removing the spacer and shorting the rod
don't follow.. ABS equiped cars split fronts at the ABS pump. Yours should already be split coming from a non ABS car. Sure your master only has ONE connection. I found this
here's an ABS master
and a non-ABS master from a '84.
as for the spacer, if removed, your brake reservoir will clear the 24v intake boot.No more e30s for me.
91 BMW 325i [sold]
why not more your old booster 1/2 drill new holes, good to go. ?
1988 325is S50 in-progress.
http://www.facebook.com/E30LocalCrew
Few pictures:
http://www.r3vlimited.com/board/showthread.php?t=255061
Originally posted by BusyMrE30 View PostYea the picture is what I confused the bottom pic is what came with my car and the top is the ix I'm trying to put on. I think I'm going to put the moded booster from zionsville. That way I can use my master and clear the boot thanks for your help guys.No more e30s for me.
91 BMW 325i [sold]
All it is is the modified E21 or 944 booster IIRC.
Check Us out on Facebook
Full Product Line Tuning
