ok so my ecu fried, watter got into it and cooked it
I got another one from a shop, he said he "put in a ews chip from a 95 car",
where as the m50tub25 DME's thru 94 did not have EWS II
the final bouch numbers on both are 413
my current results
in the new DME, I out my dinan chip in and it does not show a check engine light, but then it does supply power to the fuel pump (both hearing it prime and feeling the relay clicking on)
New DME with chip it came with it DOES show a check engine light with key on, BUT no power to the fuel pump
any ideas at all?
is there a EWS chip that can be switched over?
or is it the orignal chip? (where as I have a dinan)
would there be any other chips I can swap over from the first DME
my current results
any ideas at all?
