mechanical temp gauge, where is best place to splice in?
  • devon.818
    • Feb 2011
    • 2937
    so i picked up a mech. temp gauge for my m50 since the brown top connector didn't work and leads to me to believe the wiring is F'd up.
    i want to know where the best spot for the temp gauge's probe to go would be...are there any smally sections of hose i could tap into? then i could get a plumbing T and use nipples/clamps for a secure hold.
  • devon.818
    • Feb 2011
    • 2937
    Que?
    • Philo
      Ich esse kleine Kinder
      • 3334
      A reading from directly in the head (stock location) is the most desirable. If you have to use a hose splice, the coolant pipe for the throttle body would be a good place to use.
      -tim
      Originally posted by Jordan
      I like the stance
        • 34844
        I'm not sure how exactly you think a "mechanical" temperature gauge works..
        • ///eDirty
          • 78
          I'm using a mech temp gauge as well on my s50 project. Just use the stock location on the head, on the intake side twards the front. It's a tight fit, but you wolnt have to take anything apart to reach it. Theres two ports, 1=gauge, 1= ecu. I think the front one is for the gauge. Btw I know any sunpro universal temp gauge comes with a fitting that works. Edirty..
            • 34844
            guys. there's no such thing as a "mechanical" temp gauge. unless you're using a mercury based thermometer, or a metal coil that expands with temp... it's electronic.
            • trackjunkie21
              • Jan 2010
              • 3962
              This do you mean analog? And why do you need another temp gauge? does yours not work? Tighten the nut on the back.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • ///eDirty
                • 78
                Yea they a long hollow brass hose, gauge on one end and sensor on the other. No power required. my wiring was f' d up and the only thing keeping me from driving was that daym gauge. I happened to have a mechanical gauge laying around from a sbc project. I used it, it worked just fine... Still using it. Idk it says mechanical gauge on the box. You can get em at autozone for like 15 bucks
                  • 34844
                  there's no way that's going to be accurate with ~4ft of brass tubing radiating heat all the way to the gauge.
                  I'd rather fix the damn wiring. it's literally 1 wire.
                  • LJ851
                    • 7919
                    The gauge is calibrated to include the tubing, silly. A non electric temp gauge can be as accurate as an electrical one.
                    Lorin
                    The M30 is God's engine.
                      • 34844
                      sorry but with changing ambient conditions, engine heat radiating, airflow through the engine bay - there's no way it's going to be more accurate than a simple electric gauge.
                      • ///eDirty
                        • 78
                        your probly right I'd imagine its not as accurate as an electronic gauge. It has like a steal coil that wraps around it to keep it from directly touching anything tho. idk it works fine for me, only complaint I have is knowing just how hot an engine gets after you shut it off
                        • MattM
                          • Apr 2009
                          • 931
                          i dont see the point, the normal temp gauge is ONE wire... i could make a 'harness' for it in about 15 seconds...... lol...
                          Full Build Thread Here
                          • trackjunkie21
                            • Jan 2010
                            • 3962
                            Don't understand why you have to complicate everything.
