FYI.....lifter tick, valve noise????
  • JRKOUPE
    • Dec 2004
    • 3159
    Common to many s50's.......especially if thrashed/ tracked.....
    Bad lifter/ vanos/ kissed a valve????........consumed w/ worry?
    Take a deep breath and take off your valve cover plastic shroud, undo each of the coil packs, and check for loose spark plugs, it's very common on these engines.
    If you are lucky, you will hear the sound of a purring engine when you are done.......
    Good luck.
  • jeffmn8
    • Jul 2010
    • 217
    Also could be loose cam bearing cap nuts... At least that was the case with mine...
    Midwest Spec E30 #64
    https://www.facebook.com/thestickergarage
    • JRKOUPE
      • Dec 2004
      • 3159
      that is not really a common issue though.........nor as easily remedied....but every lil tip helps.
      • Lof8
        • Oct 2006
        • 2827
        Bump up for this thread! OP just saved me a lot of unneeded worry and work!! Thanks JRKOUPE!
        S50'd
        Originally posted by TDE30
        What is this faggy shit I have happened upon?
        I can always live in a M3. Can't M3 a house.
        • JRKOUPE
          • Dec 2004
          • 3159
          my man......good to hear!!....I can hear the sigh of relief!
          • Nick_S
            • Apr 2011
            • 3658
            Will be checking this tonight. My M50 has been getting worse.
            91 318is M50 swapped
            05 Honda Pilot
            24V swap thread
            • klodkrawler05
              • Apr 2012
              • 253
              interesting!
              I'll check this out soon, my e30 was ticking like crazy after its first auto-x this weekend and I even have baffles in my oil pan (which helped my e46 to not tick as much)
              -Brad
              My E30: http://www.r3vlimited.com/board/show...50#post3916850
              • Nick_S
                • Apr 2011
                • 3658
                This did not work for me. Mine seems to be a low oil pressure issue at idle. Bummer.
                05 Honda Pilot
                24V swap thread
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  Originally posted by klodkrawler05
                  interesting!
                  Im sure ya know that may never go away.
                  peeps have tried everything......euro oil filter /cooler......euro pan/sump...baffles...new lifters.......etc etc.....doesnt always help every1....some yes .....some no.
                  Nick......what is your hot op at idle?...you should not get "noises"...unless ur reaLLY LOW.
                  • Nick_S
                    • Apr 2011
                    • 3658
                    I'm not sure. I've been meaning to get a gauge and check it. It's far more predominate in the warmer months. It comes and goes. If I hear it starting to tick at a light or something I can rev it to around 1k or so and it goes away. I've ran seafoam, ATF and other various cleaning agents and it hasn't seemed to help. I suspect it's either a failing oil pump or a clogged passage at this point. This is in my E34 DD btw. I use Castrol 20w-50. Recently tried Rotella 10w-40 and it was noticeably more frequent.
                    05 Honda Pilot
                    24V swap thread
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      ahhh...I see....I RUN GAUGES ON MY S50.....HOT IDLE CAN GET LO...
                      i see around 10 lbs ish after hot track sessions....15/50 mob 1
