Banging, running like shit!!
  • MattM
    • Apr 2009
    • 931
    this has been pissing me off and i cannot find what it is. The random non rythmic metallic banging
    1997 M52 running full obd2.
    Facts:
    - compression is 195-200 on all cylinders
    - Camshafts are in good shape
    - nothing obviously loose in the head
    - nothing obviously loose in the bottom end
    - No engine codes
    Full Build Thread Here
  • sohc12vm20
    • Jan 2010
    • 688
    Facts:
    - No engine codes
    http://www.youtube.com/watch?v=ZU3AFGxtol4
    OK I'm just giving my opinion here.. Diffidently doesn't seem/sound mechanical. I just finished my s52 obd1 swap and it sounded and idled exactly the same, my dumb ass rushing to get the car started I ended up putting the MAF in backwards.. You know I hate admitting this publicly.. I would think it should throw a code or something. Hows the fuel pressure? Fuel lines correct?
    • MattM
      • Apr 2009
      • 931
      You dont think it sounds mechanical?
      Its a metal on metal banging noise
      Ive rotated through 2 MAF's and the results dont change
      Fuel pressure is steady 51 psi
      Fuel lines are correct
      • scottinAZ
        • Dec 2009
        • 1312
        Timing chain tensioners all in good condition?? if the idle is very erratic, and there is slop in the chains, you would get a noise similar to what you are hearing. Chances are if you get the idle under control, the noise will go away (engine isnt kicking back against the chains, causing them to rattle)
        I saved 15% on my Bimmer parts by switching to ...
        • MattM
          • Apr 2009
          • 931
          chains are tight. Ive now pulled the valve cover off again.
          • Beej '86 325es
            • 2639
            Matt, that issue I PM'd you about last week I ended up solving. My car was running horribly, to the point that I couldn't keep it running unless I gave it a lot of throttle. My new MAF ended up being bad. Did you try unplugging your MAF?
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • MattM
              • Apr 2009
              • 931
              when i unplug the MAf the car at least stays running.... but it still bangs
              • e46s54dr
                • May 2008
                • 1059
                Did you pull the head and do anything with the timing? I want to say it sounds more like an incorrect timed misfire than it does mechanical. Maybe its just the sound distortion on the video?
                • MattM
                  • Apr 2009
                  • 931
                  I havent touched anything deeper then the valve cover.
                  Its a very metallic banging noise
                  • e46s54dr
                    • May 2008
                    • 1059
                    If you are pretty sure its coming from the bottom end then I suggest your drain the oil first to look for any type of metal shavings or anything odd. Then you should remove the oil pan and have a visual inspection followed by rotating your crank manually to see if anything unusual happens during the crank rotation. I know it sucks balls but thats the best thing to do to avaoid any further damage if there is indeed something mechanically wrong.
                    • sohc12vm20
                      • Jan 2010
                      • 688
                      I don't think its mechanical.. From what I could hear on me work computer.. Your ignition coils are fine? Ive heard a few of these engines make knocking sounds with faulty ignition coils. However they did maintain a some what steady idle. My guess would have been the MAF, but if you've already address this, that's also true, engine could be out of timing.
                      • sohc12vm20
                        • Jan 2010
                        • 688
                        Just to add, a week after I bought my M5 I went to start it and it cranked and died.. I went to start it again and the car could barely idle almost seemed like the engine was about to blow. So I find out apparently the engine had a faulty timing chain tensioner and so when I went to start it the 2nd time the chain had already jump forward. Heck I thought the engine was done. Anyhow of course car was under warranty and was fixed by BMW.
                        • MattM
                          • Apr 2009
                          • 931
                          disconnecting the maf makes it idle somewhat steady, but it still bangs and clanks around... i notice with the maf unplugged there is a slight dip in the idle right before it bangs
                          • DesertBMW
                            • Aug 2011
                            • 1043
                            To me sounds like low rpm pre-ignition and forces the piston slap to rattle in its bore causing loud mechanical knock. Maybe you mixed the coil connectors because ignition timing is off.
                            Noise is random, if the noise was rhythmic and constant then I would believe that there is something lose in the engine.
                            This person has the same problem but it is do to worn engine bore and not wrong timing:
                            • e30rapidic
                              • 2167
                              I'm thinking you have 2 or more coil connectors wrong as well
                              '87 325ic, powered by S50.
