Sup guys, over summer I had completed my m50 swap on the e30 and right after, fall semester started so I didnt have much time to work on the small bits of work needed such as cluster lights not working, temp gauge not working, and this annoying rev hang im getting :hitler:.. Ever since the swap I've had this rev hang when I drive. Id let off the gas when in gear (or neutral, but not as bad) and the revs would just sit for a couple seconds, then start to die down. Feels like im driving a damn e46 which = :roll:.
Thing is when I disconnect the maf plug, the rev hang would go away, but would give birth to an idle spasm. Swapped maf's and same thing happened, so it cant be the maf.
Anyway, heres a vid showing what I mean. I know its kindof hard to see/notice it with the angle off and the sun glare in the way, but its the best I can do. In the vid I'd accelerate and then let off the gas right away (in most of the vid) and the times when the revs stay in place is when I let off the gas.
Any ideas?
Any ideas?
