Your experience: what was the hardest part of your 24v swap?
  • AnimalE30
    • Aug 2009
    • 266
    #46
    Money and time.
    My car has been sitting in my dive way for three weeks now with the motor in. All it needs is an exhaust and alignment.
    • ACHTUNG
      • May 2005
      • 2397
      #47
      writing the check
      1989 US E30 Cammed S52
      Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
      • ayemattyyy
        • Apr 2008
        • 411
        #48
        Just finding the time was a chore all on its own.
        Matt
        • GDA
          • 446
          #49
          Time and nailing down all the little parts so its done right.
          I am doing a major resto and lots of mods along the way so it has definitely added to the parts/sourcing complexity.
          • alpinescott
            • Apr 2011
            • 114
            #50
            Having everything done and now trying to figure out why all of a sudden my brakes are seized........UGGGGG
            • TimKninja
              • 2131
              #51
              ^^^crack a bleeder screw. Sounds like you didnt trim the booster enough.
              I should also add, remove the A/c condensor and bracket before putting the engine in the bay. Makes life alot easier.
              1985 325e M50TU(Sold)
              1991 318is Slicktop (Sold)
              1990 325is Brilliantrot S50/5 Lug Swapped.
              1992 525i Manual shitbox Winter Beater
              • MR E30 325is
                • Dec 2008
                • 3300
                #52
                For all of the 24v swaps I have been a part of, the hardest part has to be the little things. Not having the appropriate bolt, or the right tool really adds a lot of time to an already long task.
                No matter how much you prepare in advance, if you havent done at least one before, you wont have everything covered. So be ready to accept defeat at points, and run to your local hardware/auto parts store in the DD to make the swap happen.
                I am about to remove my S52 over the winter and do lots of maintenance and cleaning of the engine bay to get it just how I want. I am sure it would have been much easier the first time around, but I didnt have the time.
                My previous build (currently E30-less)
                http://www.r3vlimited.com/board/showthread.php?t=170390
                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                • Jand3rson
                  • 37587
                  #53
                  That happened to me, and it was the fork/clevis pin that attaches from the booster pushrod to the brake pedal arm, I had it adjusted out to far, and it wasn't allowing the booster to release the built up brake pressure.
                  • r4esh
                    • Jan 2010
                    • 439
                    #54
                    s52 e30 m3 = late nights, time away from family, work neglected, savings gone, and a very tolerant and supportive wife... thank god it runs now. Squeezing time over that past 3-4 months was a challenge.
                    (oo=[][]=oo)
                    Web Design PNW
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      #55
                      Replacing the damn diff sucks. Everything else is straight forward if you have mechanical aptitude.
                      Originally posted by 325Projectz
                      don't listen to the diagram... listen to mr. swiss.
                      :nice:
                      • Matt-B
                        The Waffler
                        • 3856
                        #56
                        Originally posted by rThor432
                        ^^Lol, must have been a real tough swap if bleeding the clutch was the hardest part.
                        nothing about my swap was hard. only thing i had trouble with is bleeding clutch, and removing chain from back of motor after putting it in
                        • sharky
                          • Jan 2005
                          • 2672
                          #57
                          boosting it
                          • TimKninja
                            • 2131
                            #58
                            A word of advice.
                            If your rear main looks good. Leave it alone.
                            Guess what my brand new fucking rear main seal does?
                            • BoostinEuros
                              • 363
                              #59
                              A word of advice.
                              I'll take that advice!
                              '91 "318is" slick top M50 turbo
                              '97 Dodge 3500 12v Cummins
                              '12 Mini Cooper S
                              '89 318i Chump Car Project
                              • gp.plus
                                • 416
                                #60
                                I had my obdI m52 swap in and running in 2 days, then spent 4 day trying to bleed the f'ing coolant. Finnally had my bud bring over an "airlift" tool which sucks the air out of the system till the hoses collapse, then draws nothing but coolant back in. Now good to go, and loving every minute of it!
