M50B20 cams vs B25 cams...
  • wakdog
    • 223
    So I need to pull my head some time soon and have found a guy that will give me a M50B20 motor, what I was wondering is, do both the B20 and B25 use the same camshafts? (both non vanos)
    What I was thinking is that seeing as ill have the head off, ill pull the cams and replace the lifters, but while im there i was going to try and get a second intake cam and run it exhaust side (this is better from what i have read).
    basically just wanting to see if i can get an answer without having to pull the cam out of the B20 if it isnt going to help me......
    90 318i M62B44 OBD1
    02 530i Touring (Airlift 3P)
  • MaxBell
    • 1391
    Anyone got any ideas? I've heard that the 320i M50 cams are an upgrade for the M50B25.
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    • NedMW
      • 26
      B20 cams are reportedly more agressive, check catcams.co.uk perhaps?
      • wakdog
        • 223
        I have actually got these cams and plan to put them in with low mileage lifters in te next week or 2, will report back with dyno comparisons next time i get on one.
        90 318i M62B44 OBD1
        • NedMW
          • 26
          I have a whole B20 head, gonna make me a high(er) comp 2.8... One day...
          • wakdog
            • 223
            The only part of the B20 head worth using is the cams, the rest is crap... It has smaller ports than the B25 and wont make anywhere near as much power...
            90 318i M62B44 OBD1
            • NedMW
              • 26
              I think it's possibly cooked, it blew a head gasket but there was no breach in the gasket so I think the head might be a gonner anyways...
