Point taken, still tempting me :) I will see what I can come up with over this winter
S50 Cams into NVM50?
So swapping the M54 rotating assembly into the M50 block will just produce a 3.0 M50 right? Which would essentially be the same as an S50 short block?Comment
Not really.
Pistons are be nicer ; lighter as smaller bore.
sides are coated. The e46 pistons got fancy coating on the skirts.
Stroke is much longer. Bore is smaller.
S50b30 USA is old in comparison; new stuff = advancement, nicer lighter and smarter.OBD1 M54/M52TU swap as a M50b25
Nice, thats what I like to hear :)
Thanks alot for your patience and answers to my Q'sComment
It's thanksgiving !! Need to get in the holiday spirit!
Smaller bore seems to allow the hg to hold more boost as the bigger bores have less space for sealing.
This having been said my fav engine (s54) is Oem 87mm bore and has almost no thickness between
cylinders. :p
S52 is 86.4 bore
S50 is I don't know bore
M50 and m54 are 84mm
Bore.OBD1 M54/M52TU swap as a M50b25
Sweet, thanks for letting me know!Comment
