Hello guys. I have a s52 engine with speed transmission. Maybe you someone here has experienced the same problem and knows a solution. While driving after shifting into 5th, I let go of the gas a bit and 5th gear pops out. What could be the problem here? thanks in advance for those of you willing to help...
Transmission Problem: Fifth gear pops out...
Sounds like it's time to do your shift pins and detents:
I just did mine while I had my ZF out of the car; very straightforward and the repair kits are cheap.
'91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
'87 535i - Vacuum brake conversion [SOLD]'93 525iT - 5-speed swap - 320k and counting'09 328xi - 6-speed
Detent pin. May as well do both at the same time. I did, ordered from Bluntipoo. About a $30 fix....much cheaper than replacing trans....
23 11 7 542 726 Repair Kit X2 (Contains 1 bushing, 1 seal cap, 1 lock ring)
23 31 1 224 849 Locking Pin X1 (Detent Pin, Reverse)
23 31 7 502 165 Locking Pin X1 (Detent Pin, 5th gear)'87 325ic, powered by S50.Comment
:nice:Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
Like I said above. Not hearsay, I did it...
