g260 shifting issues.
  • howelll
    • Sep 2009
    • 198
    Has anybody had any shifting issues after a swap using the 260. My gearbox locks me out of second when I'm driving hard with high rpm. I'm wondering if it has to do with the swap or is it just a bad synchro.
  • scottinAZ
    • Dec 2009
    • 1312
    did you have any issues with the trans beforehand?? I would check for interference with the shift rod and the driveshaft, and if that all checks out, call the transmission toast....
    I saved 15% on my Bimmer parts by switching to ...
    • howelll
      • Sep 2009
      • 198
      I don't recall any issues before the swap but i really didn't drive it much before the swap. It shifts fine driving light and shifting at lower rpm's. I thought i read somewhere in someones build that they shimmed one side motor mount to fix the same issue. It may be time to go with a zf.
      Sent from my DROID BIONIC using Tapatalk
      • 328ijunkie
        • May 2007
        • 3961
        ZF time ;)
        Unless your shifter is bricked which it prob is
        Check Us out on Facebook
        Full Product Line Tuning
        • howelll
          • Sep 2009
          • 198
          Originally posted by 328ijunkie
          ZF time ;)
          bricked? What do you mean? Shifter is a new x5 lever with a zhp weighted knob in a sheet metal carrier bolted to the car. There's no interference with any of the parts and plenty of clearance.
            • 37833
            Shimming a motor mount isn't going to make your trans shift better...
            Grover Beach, California
            BimmerHeads.com
            • howelll
              • Sep 2009
              • 198
              I didn't think it would either, I thought it was weird when I heard it but I had to ask.
              • Fusion
                • Nov 2009
                • 3659
                Is the shifter straight when in neutral?
                My old car used to lock me in second a lot when it was freezing outside, had to hit that bitch out. Dissappeared when the engine got to operating temp.
