Clutch/PP/Fly for 500whp?
  • GunMetalGrey
    • Dec 2010
    • 1499
    I am working on my swap and need a clutch, pressure plate, and flywheel for my m50tu. I would like to have it streetable but be able to hold the 500hp down. Any thoughts? Going with a gt260
  • Jszy25
    • 352
    I'd give Clutchnet and Southbend a call. Both can make you a single disk (full face) clutch kit that will hold the power and be very streetable.
    91' 318is - OBDI M52/ZF swap w/ S50 cams
    • Adrian_Visser
      • Jun 2006
      • 2823
      Make sure you go with the 240mm disc from the e36M3, you will also need a 240mm flywheel.
      '89 Alpine S52 with goodies
      • GunMetalGrey
        • Dec 2010
        • 1499
        I would like to try to spend around 600 or less lol. Don't know if that is possible. I am not boosted yet, so that is a thing.
        • Nairb
          • 1214
          That is a hell of a budget for such a high powered car. I hope you are good at fabrication, that's all I can say.
          Good luck!
          My 1991 318is Progression Thread
          • ogbimmer
            • Jul 2010
            • 936
            I got a 4 puck sprung clutch made for $280 and a sachs 618pp for $300 I think.
            " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
            • Jszy25
              • 352
              Good luck!
              Hes talking about the clutch kit haha
              $600 is do-able for a clutch disk/PP combo that can hold the power and be streetable. I'd stick with a stock dual mass flywheel and get an unsprung disk.
              • AnimalE30
                • Aug 2009
                • 266
                Which company has a high clutch failure rate? I know the guys on bimmerforums FI were all moving from one of these companies to the other due to the large number of failures, but I'm not sure which one.
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  A dual mass would not work, it would just get ruined or be constantly slipping, unless I got one made for the power curves, and that would just be expensive. IS the s50 clutch pp and flywheel much larger or better than an m20 setup? The price on the two is plenty different. ANd have any of you guys used ebay clutch systems? I usually would stay away from those but I know that a few people on here run them. If I use the s50 clutch setup I cannot use the m20 starter correct?
                  • drumad
                    • Aug 2009
                    • 1700
                    iirc the m20 flywheel is 228mm and the m5x/s5x flywheel is 240mm
                    your flywheel must match your starter
                    2008 335i - n54b30
                    1991 318i - m52b28
                    1994 fzj80 - LAND CRUSHER
                    • GunMetalGrey
                      • Dec 2010
                      • 1499
                      THanks for the info, we have the same two cars lol
                      • Jszy25
                        • 352
                        I'm confused, why would it get ruined? You tell the clutch manufacturer what flywheel you are using and they build you a clutch kit for it. It works great.
                        • Jszy25
                          • 352
                          To be honest, they both have had failures, just like every other clutch manufacturer. They still have tons of happy customers though (both companies).
                          • Dominic49
                            • Feb 2007
                            • 1373
                            I have seen one of my fullface clutches hold over 500tq with a clutchnetred plate
                            i have held over 350 tq with a factory m3 plate
                            • AnimalE30
                              • Aug 2009
                              • 266
                              Ohh okay lol. I thought it was one more than the other. My bad!
