Originally posted by GunMetalGrey
View Post
Dual mass eats the shock loading at the flywheel, saves the Pressure plate springs from a decent amount of shock, allows longer transmission and driveline life/durability under high loads/shocks/torque. kill the flywheel instead of transmission.
G260 transmission gets baby size 228mm clutch natively for e30.
G260 transmission is designed to take a 240mm Clutch kit natively by Getrag; reference e32 735i.
G260 is shipped from factory with both dual mass and single mass clutch setups in both 228mm and 240mm.
240mm is bigger than 228mm. Bigger = hold more torque, more heat.
Dual mass vs single = not much difference in weight
comparing factory 240mm setups: (complete flywheel+pressure plate+friction disc). All three of these can hold ~ 370rwhp also.
e36m3 S52b32 complete dual mass setup weight = 32lbs
e24 m30b33 633csi single mass weight complete kit 29lbs.
e46 330i ZHP dual mass complete kit = 30.5 lbs
S52b32USA's complete OEM new clutch kit is good for over 370rwhp, and also fits perfect in your G260 (I DD a G260). This factory setup can be daily driven in 3rd world country traffic and wound out on the track or on Wangan. Cost is not very much either.
you can buy a turbo aftermarket Pressure plate and friction disc set to pair with the S52 dual mass flywheel.
A Brand new s52 (USA e36m3.2) dual mass LUK (germany) is under $400.
Call southbend/SPEC and ask for a 500rwhp turbo s52 clutch -both companies can deliver a DD-able 500rwhp clutch.
The Dual Mass 240mm diameter Clutch setup has been proven in e39M5 V8 5.0L application (Original from BMW).
you could also go the cheap ebay f1grpfrce route and get an entire setup for a e36M. If you pick the right one and are lucky on manufacturing tolerances it should be just fine.
