and the check engine light does work, unplugged my MAF and it came up, unplugged my O2 and it also came up. womp :/
M50NV cuts out going from idle to WOT
Definitely check your fuel pressure with a guage. If the pump is weak or dying, it wont be able to pressurize the fuel lines in time. Have you tried reving the engine and keeping it steady at say 5k rpm? Try that and see if it hesitates or even dies out.
Tps
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Holds it steady.
You think so? What makes you so sure? Will buying a known-working one cure my idle?
I vaguely remember my idle on my M20 improving somewhat dramatically when I changed the TPS.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
ICV me thinks.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
Do you have a multimeter? If you do, try testing your tps sensor. Also, its a long shot but have you tried playing with the adjustment of your throttle cable? Maybe theres too much slack?
If you dont have a meter, it wounldnt hurt to try and change both the icv and tps. Both items will amazingly fit in your pocket nicely if you just so happen to hit up a local pick a part.:D
Lastly, try unplugging your idle control valve to see if anything changes....Last edited by e46s54dr; 12-19-2011, 06:12 PM.
Man, i thought you were all good, then i see this. I agree you should start by checking the fuel pressure w/gauge, you could have a clogged filter, or the pump may not be keeping up at wot. The icv should not cause issues beyond idle, as more than enough air is flowing through the tb. grab a fuel pressure test kit from harbor freight, clean it up and return it when done, or see if autozone "lends" them, i believe they require a deposit but there is no rental charge.
have you checked for vac leaks w/ a can of carb cleaner? spray it around possible leaks and listen for the idle to increase, try spraying the injectors, good chance the lower o-rings are toast. i pulled a set w/185k on em , and the o rings literally crumbled off.Comment
Unplugged my ICV while car was cold and the idle was surging, nothing happened except a CEL! Time to give it a good cleaning?Do you have a multimeter? If you do, try testing your tps sensor. Also, its a long shot but have you tried playing with the adjustment of your throttle cable? Maybe theres too much slack?
I've tried vac leaks with carb cleaner and I can't find anything, im thoroughly convinced I have none!Man, i thought you were all good, then i see this. I agree you should start by checking the fuel pressure w/gauge, you could have a clogged filter, or the pump may not be keeping up at wot. The icv should not cause issues beyond idle, as more than enough air is flowing through the tb. grab a fuel pressure test kit from harbor freight, clean it up and return it when done, or see if autozone "lends" them, i believe they require a deposit but there is no rental charge.
The problem with it surging and cutting off at high RPM's seems to have gone away with the FPR though, it just cuts off at idle now when it's surging and I go WOT.
fuel pressure test will be my last resortOriginally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
I'm still getting complete cut outs and complete motor death on the highway at cruising speeds. I'll be driving at cruising speed, then it'll start cutting out, then i'll try to keep the revs up by giving more throttle but it doesn't do anything, then I'll downshift to 4th to keep the revs up which either saves it or kills it completely..then the motor will be moving while still in gear, but absolutely dead.
Could my coolant temperature sensor be causing this? because it seems to happen at only operating temperature.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Texted!
On another note, I'm thinking its a very serious fuel delivery problem.
the only CODE I get is 1263, which is Fuel vent which is the purge valve that I don't have connected, the vent line from the gas tank is just chillin in my engine bay
When I went WOT from a launch, the car hauled ass in 1st gear, then as I went to shift into 2nd it just immediately died. The car was cold too so i can't imagine it being related to coolant temp sensor since it wasn't at operating temperature.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
changed the ECU, NOTHING.
changed the fuel pump, NOTHING.
I mean I don't have my purge valve connected and the vent line from the fuel tank is just venting to atmosphere but i DOUBT that's it.Last edited by lolcantturn; 12-25-2011, 02:38 PM.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
crankshaft sensor? camshaft sensor?Comment
I think a failing crank sensor would disable the motor completely from starting right? What does the cam sensor do? Because I'm thinking it's that..Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Sometimes they go intermittently bad. get some known good ones and try it couldn't hurtComment
