Cam sensor retards/advances ignition timing
M50NV cuts out going from idle to WOT
shall I point out that, when the car dies, it has NO problem starting back up, as if nothing ever happened.
I have no vacuum leaks (smoke tested) ...Last edited by lolcantturn; 12-25-2011, 05:53 PM.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
Originally posted by lolcantturn View Postshall I point out that, when the car dies, it has NO problem starting back up, as if nothing ever happened.
I have no vacuum leaks (smoke tested) ...Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.
Originally posted by lolcantturn View PostDEARi KAMIL,
I DONT THINK MY ICV IS GONNA CAUSE CUT OUTS
SINCERELY,
LAUGH OUT LOUD, CANNOT TURN.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by trackjunkie21 View PostYeah but you said you start the car and it dies at idle, hence why I said Idle Control.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
After checking the car out today, the problem seems fuel related, After messing with the injector harness ground wire the car ran somewhat better and didn't cut out as often, I'm suspecting an old clogged filter is causing most of the issues.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninja View PostIt has nothing to do with your vent thingy. I have mine set up similar except its still plugged in.
Did you change your TPS? Get a JY one for the lulz.
Originally posted by trackjunkie21 View PostAfter checking the car out today, the problem seems fuel related, After messing with the injector harness ground wire the car ran somewhat better and didn't cut out as often, I'm suspecting an old clogged filter is causing most of the issues.
The car had 9month old gas in it before i started the M50, i guess it's all clogged up. I hope at least. tired of throwing parts at this.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
Did you change your TPS? Get a JY one for the lulz.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by lolcantturn View PostAlso not running coil grounding straps tho I doubt that has anything to do with this
"The studs go into the valve cover which is separated from the head with a rubber gasket. How well is that going to ground to the block? The only connection between the head and the coil is through the small contact point at the top of the spark plug. The early M50's with the almn. valve covers provided some grounding but the later M52's with the plastic valve covers have zero grounding properties. I'm not just pulling stuff out of the air here, I work at a BMW shop and have seen this problem. 90% of the time when a coil starts to short out or isn't grounded properly and it isn't taken care of in a timely matter the DME will die"
