My dad's about to kick my ass - Oil Leaks
  • Rsully70sev
    • 2391
    My dad absolutely hates oil leaks, especially on the driveway, garage floor, etc. I need help with these, I managed to find where they are coming from, can I get some input on what's causing this? All help is much appreciated, not exactly what I wanted to deal with my third day of ownership-but hell, it's a BMW.
    I figured the extensive photos would help. Thank you for your input, I want to get this resolved as soon as possible.
  • smyleboyd
    • Sep 2011
    • 1164
    Bad crankshaft seal?
    • Killacortes
      • 1937
      Where's my belt?! I'm bout to beat your ass like a red headed stepchild
      r3v does not fuck around. First you get banned, then they shoot you
      • Rsully70sev
        • 2391
        Well, as for the oil pan I think I just need to get a new plate, gasket, etc. I found this:
        11131726357 cover lid - list $7.98
        12611277129 gasket ring - list $2.01
        And for the bolts on the transmission, it could be old ass tranny fluid I'm mistaking for oil. All I know is it's dirty as fack and leaking. I'm thinking just replace it with new crush washers and bolts.
        I'm going to degrease and power wash all the bullshit off it, then see what exactly is leaking. I'm hoping it's not a bad crankshaft seal, I'm not trying to drop the transmission so soon!
        Seriously dude, my dad was sooo pissed when my M20 pissed oil everywhere. I promised him this one wouldn't, so he let me park it in the garage and BAM! Stains
        • Schniddy
          • May 2004
          • 3818
          Definitely try using degreaser to narrow down where it's leaking.
          Also, try removing the flywheel cover, and check under there--it could be coming from the oil pan gasket, or rear transmisson seal.
          • Holland
            • Nov 2008
            • 7212
            Degrease, then dye, then blacklight.
            Originally posted by DEV0 E30
            • Rsully70sev
              • 2391
              Can you reccomend a dye?
              • scottinAZ
                • Dec 2009
                • 1312
                napa carries it, just ask at the counter
                I saved 15% on my Bimmer parts by switching to ...
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  Looks like the oil level sender O ring is leaking on the oilpan, the power steering which is fairly normal for BMW and your transmission.
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • kts
                    • Jun 2010
                    • 753
                    ^^ this.
                    A good degreasing, scrub, and power wash should help remove most of the oil on the driveway as well and keep your dad happy.
                    I think the plate is probably fine, I would just replace the gasket and save a few bucks.
                    • 110stx
                      • Sep 2011
                      • 253
                      Leaky power steering lines too, it appears.
                      Rear main seal will leak out the bellhousing and blow back on the tranny while you drive.
                      STX e30
                      No. 10/110 STX: 1989 325i
                      DD: 1991 318is slicktop
                      SHAZAM, GOMER, LOOK AHEAD.
                      • priapism
                        • 1182
                        FJC makes a good dye.
                        -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
                        • Desaevious
                          • Aug 2007
                          • 3810
                          My dad is the same way. He makes me park on a side driveway of stone dust we made because it was ruining his precious asphault. That driveway is under a pine tree and collects sap....:(
                          It looks like it. When I replaced mine it was hardly there...just a small remnant of the red gasket it once was. I have ZERO oil leaks now...but that is because I changed every seal and gasket when the M20 was out of the car this past summer.
                          SC*AR (Schwarz Army)
                          • nomansland92
                            • 1657
                            Put some 20w50 in her
                            IX being restored here
                            Ix turbo build here
                            • Rsully70sev
                              • 2391
                              ^ not sure if seryius? On an S50?
                              Thanks for all the input guys. I'll try the dye and get some more pictures up soon.
