S50B30us isn't sitting right
  • yanal
    • Jun 2011
    • 248
    So I finished putting the engine in today but for some reason the transmission isn't sitting right, I'll replace these mounts with a solid ones but I just wanted to see how it sits first, I used two e28 535i engine mounts. The driver side looks perfect but indoor like the passenger side. Also the shifter carrier isn't centered, any suggestions ?
    It's a s50b30us with a 95 M3 transmission in a 1992 convertible.
    Sticky:True e36 one touch windows DIY
    1990 M3
    1992 Mtech (S50 + 5 Lug)
  • 328ijunkie
    • May 2007
    • 3961
    flip the mounts around (bolt through tab hole and tab through bolt hole)
    Check Us out on Facebook
    Full Product Line Tuning
    • yanal
      • Jun 2011
      • 248
      I'm new to this so bare with me, you're talking about the alignment tab underneath the green mount, Correct ? And doing so will fix how the transmission is sitting on its mounts ?what about the shifter carrier ? Should I just leave it ? Btw it's the shifter carrier that came with the 95 M3 transmission I think it's the ZF320 or something
      1990 M3
      • yanal
        • Jun 2011
        • 248
        Christmas bump, anyone ?
        1990 M3
        • jahnaboi
          • Oct 2006
          • 1742
          Yes. Flip the green mounts. Should give you more wiggle room. And as far as the shift carrier goes, use e30 everything minus the lever.
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • yanal
            • Jun 2011
            • 248
            I got rid of all the E30 stuff because everyone said use all ZF parts ugh!
            1990 M3
            • nrubenstein
              • 3148
              You can use all the E36 parts. The shifter is fine. It'll line up when you get the engine mounting sorted.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • yanal
                • Jun 2011
                • 248
                Sweet ! Thanks guys, I'll flip the mounts tomorrow and report back.
                Any idea where I should buy the re-enforced transmission mounts ? I'm using the mechanical fan and I read somewhere that if I don't enforc the trannys mount it will end up destroying the radiator once I slam the brakes
                1990 M3
                • nrubenstein
                  • 3148
                  AKG is one source.
