Is this S52 obd1?
  • alB5
    • 785
    Is this S52 obd1?
    The guy I'm buying it from took it out of a 92' 325i so it's possible the original owner had installed it obd2.
    I'll update with more pics when i get them if this doesn't suffice.
    1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
    No E30 Club
  • Nairb
    • 1214
    If it is OEM then it is OBD2.
    All s52 were OBD2 from the factory unless they had been converted.
    My 1991 318is Progression Thread
    • Holland
      • Nov 2008
      • 7212
      Well the intake manifold is from an S50, but that doesn't necessarily mean it's obd1.
      Originally posted by DEV0 E30
      • surebimmer
        • Jan 2004
        • 978
        I see a secondary air valve so my guess is that It's obd 2.
        • mammoth_e30
          • Nov 2009
          • 818
          Which is odd because there is no secondary air pump? How many O2 sensors does it have hooked up?
            • 37833
            Looks OBD1 to me judging by the MAF it's running.
            Grover Beach, California
            BimmerHeads.com
            • 328ijunkie
              • May 2007
              • 3961
              Thats running OBD1.
              Check Us out on Facebook
              Full Product Line Tuning
              • Mr.SWISS
                • Nov 2005
                • 1251
                My thoughts, and there is no running losses valve in sight and the egr on the exhaust mani is not hooked up.
                $20 says it has a crank sensor on the front and the rear one is not hooked up.
                Originally posted by 325Projectz
                don't listen to the diagram... listen to mr. swiss.
                :nice:
                • e30s50dan
                  • Nov 2008
                  • 2076
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1991 318IS slick top
                  1997 M3 sedan
                  2001 325CI DD
                  “whoever turns the wheel the least, wins"
                  • alB5
                    • 785
                    thanks guys, i'll post up more shots when he sends them just to confirm. I'm extremely excited and getting this for a steal (although without the zf transmisssion).
                    No E30 Club
                    • alB5
                      • 785
                      has a 413 dme, now the parts hunt starts.
                      No E30 Club
                      • scottinAZ
                        • Dec 2009
                        • 1312
                        413 is OBD1.
                        I saved 15% on my Bimmer parts by switching to ...
                        • alB5
                          • 785
                          yup, (if it's not clear i just bought the motor) going to use my g240 with other flywheel/clutch combo and see how long my 4.10 diff lasts.
                          No E30 Club
