E30, S50, OBD1, War Chip. silver label DME, EWS cut.
Parts replaced so far:
O2 Sensor (oem)
Crank Sensor (oem)
Cam Sensor (oem)
Coolant Temp Sensor (oem)
Fuel pump (twice)
MAF (oem)
Battery (deka agm)
Plugs (OEM)
Car does not like to idle really smooth. Some time ago, checked to see if O2 sensor was getting voltage. It was not. Checked relay, and the relay was feeding the DME 12V, but the O2 sensor was not getting 12v. Replaced relay, and sensor, and IIRC, problem was solved. DME stopped getting 12v (dme grounds relay to activate relay as far as I can tell?)
Car also likes to break up at around 6500RPM. Replaced DME and WAR chip, and the problem went a way for a very short while, then came back. Then, it started cutting out severely, idling VERY rough, dying. Felt like fuel pump dying. I would turn car off, restart, and it would chug along, but not run great. Replaced fuel pump. Checked fuel pressure. Etc etc. Problem still there. Went back to old DME, and the problem went away for a few minutes. Then it came back. So I checked the O2 sensor relay that I had replaced (above) with one from my parts car, and again, the DME was getting fed 12v via the wire that is supposed to ground the relay. Pulled the O2 sensor relay (hence removing the 12v feeding into the DME, where it should only be ground), and the car instantly came to a smooth-ish (but not perfect) idle. Car ran/drove fine. First 5 miles or so, hit limiter no problem. Then, as I got close to the house from work, it again is breaking up at 6500RPM.
And I am stumped.
Another side note: INPA 5.0 w/BMW cable refuses to connect to the DME via the 20pin diagnostic port. Both DMEs. Switched 12v power (pin16) in X6002 diagnostic port has no 12v. I manually applied 12v to pin16, but still no dice.
Ideas?
O2 Sensor (oem)
Crank Sensor (oem)
Cam Sensor (oem)
Fuel pump (twice)
MAF (oem)
Battery (deka agm)
Plugs (OEM)
And I am stumped.
Ideas?
