Anyone ever use a vacuum bleeder for cooling system and what electric fan to use?
  • Jand3rson
    • 37587
    Originally posted by 5mall5nail5
    Do you guys run ok with a pusher? I was thinking of going with a 14" puller, but a pusher would be better because I don't have to worry about room limitations as much.
    I'm running a 16" SPAL pusher on the front of my M42 radiator, fits perfectly. I wanted the pusher because I was trying to keep as much out of the engine bay as I could, so mainly for aesthetics, but they work just fine. You'll want to fab some mounts up for it like we did, those zip-tie things they come with are garbage, and will actually wear through the radiator fins.
    I also had to do a little massaging of the seam on top of the front core support to fit the fan in there, the shroud was hitting it and the radiator wouldn't sit down in there all the way.
    • nrubenstein
      • 3148
      I don't know how you guys get away with just using a pusher fan. Mine won't tolerate that.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Jand3rson
        • 37587
        Different climates. I live in the mountains (about 3600').
