s52 oil leak
  • AldcE30
    • 66
    s52 oil leak
    i have oil leak coming from the back of the engine somewhere its definitly not the head or valvecover gasket, im pretty sure its not the oil pan gasket and i just changed the rear main seal and the o-ring over the crank sensor below the starter, a friend of mine thinks its may be that plate that sits around the rear man seal , and suggestions ? and has anyone changed this ?
  • scottinAZ
    • Dec 2009
    • 1312
    could be the plate for the rear main, or could still be the rear main. Very easy to get the seal a tad cockeyed and still have leaks. can also be the flywheel bolts if you did not use sealant on them
    I saved 15% on my Bimmer parts by switching to ...
    • M-technik-3
      • 18946
      Rear main seal or the plate, they can be troublesome.
      • 328ijunkie
        • May 2007
        • 3961
        you change the plate gasket?
        Check Us out on Facebook
        Full Product Line Tuning
        • TimKninja
          • 2131
          I have the same problem. Changed the rear main , now it leaks like the exxon valdez. Gonna pull the tranny round spring time to fix it.
          I dont know if it makes a difference, but i think i had the cork gasket and changed it to the metal gasket. Cant find the cork one anywhere.
          1985 325e M50TU(Sold)
          1991 318is Slicktop (Sold)
          1990 325is Brilliantrot S50/5 Lug Swapped.
          1992 525i Manual shitbox Winter Beater
          • Jonny Cash
            • 1763
            Yea there seems to be two designs for the rear main. Theres a new(er) comes with a plastic guide to set the seal in, it can be tricky to set in there. Might want to remove and re-install the seal to make sure its not pinched somewhere- better to take off the entire unit and seal it back up as a unit without having to buy a new seal.
            -Jay
            2014 NASA FL se30 champ #81
            2001 se46 3 year plan in progress
            • 5mall5nail5
              • 156
              The rear main seal is actually sold as a "kit" from BMW. It comes with a NEW plate, gasket, bolts, and rear main seal already installed in the plate. It works much better than just replacing one gasket/seal.
              11142247867 "set of covers" is the best way to go.
              Looks like this:
              • 328ijunkie
                • May 2007
                • 3961
                ^That.
                What i use on all my customer cars. Called a 'repair kit' or w/e
                • AldcE30
                  • 66
                  that 111 number is the part number from bmw?
                  • AldcE30
                    • 66
                    i appreciate all of your help im going to try that kit, is the rms pre installed in that plate? also what is that kit going to cost me from bmw and is there an aftermarket one that may be better ?
                    • AldcE30
                      • 66
                      once again thanbk you for all your help, im just asking so many questions because i want to be 100% sure that this thing wont leak again once the tranny is back up, its not fun taking the tranny out !
                      • 5mall5nail5
                        • 156
                        OEM is best, always:
                        http://www.ecstuning.com/Search/11142247867/
                        $83
                        Yes the rear main is pre-installed.
