Right motor mounts?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Right motor mounts?
  • PuebloPete
    • Oct 2005
    • 161
    I'd go with one of these IMO. More expensive, but much better quality. I went with the solid aluminum ones. My $.02
    http://www.akgmotorsport.com/catalog...0%2FM50%20Swap
    My build threads
    http://forums.bimmerforums.com/forum....php?t=1435735
    http://www.e30tech.com/forum/showthread.php?t=93896
    • 328ijunkie
      • May 2007
      • 3961
      no.
      Check Us out on Facebook
      Full Product Line Tuning
      • Elysian
        • 674
        Those are the same mounts I had in my E24... When they go, they go pretty bad. No thanks!
        • 328ijunkie
          • May 2007
          • 3961
          Never had an issue. Been running them in various cars for years...
          • GunMetalGrey
            • Dec 2010
            • 1499
            Got it, thanks!
            • burkey001
              • Feb 2011
              • 608
              The AKG mounts will sit the motor further back in the engine bay and lower than the E28 M5 mounts.
              This is better IMO, for the heavier weight of the M/S50.
              88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
              90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
              • 328ijunkie
                • May 2007
                • 3961
                Ive used the AKG mounts (im a vendor for them) and as long as you dont do any crazy shimming of the E28 mounts they work perfect. Ive used both in customer cars...
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  I like the lower and farther back, but another 60 is a tad much for now. Maybe down the road!
                    • 37829
                    Most people don't want their engine lower due to pan clearance.
                    I have used the E28 mounts on every swap I've been involved with and prefer them.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • GunMetalGrey
                      • Dec 2010
                      • 1499
                      Any thoughts on sub frame reinforcement ?
                      • bzboardz
                        • 1096
                        +1 for e28 mounts
                        • White325is
                          • Oct 2006
                          • 5947
                          Id go with a soft mount.
                          Solid mounts like the AKG ones just mean broken aluminum engine arms when you big nasty bumps. If you dont catch it when it happens then you end up with broke oil pans.
                          • ScHpAnKy
                            • 1573
                            for those using the e28 motor mounts, did you shim yours? I did about 1/4in drivers side and 1/2in on the passenger side to lift the oil pan and give my exhaust manifolds some clearance. I'd be interested to hear responses on how it worked out for those that didn't shim their e28 mounts and what sort of clearances you've had.
                            91 318i | 87 535iS
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              no shims and about 10-15mm clearance on headers to subframe, about 8-10 mm on booster to manifold.
                              Originally posted by 325Projectz
                              don't listen to the diagram... listen to mr. swiss.
                              :nice:
