Retrofitted an aftermarket water temp gauge into the cluster
  • jeffmn8
    • Jul 2010
    • 217
    I know most of you aren't big fans of the oem water temp gauges. After I swapped in my s50, my temp gauge wasn't working (I forgot to pick up the brown sensor.) So after a while I picked up an autometer sport comp short sweep gauge from the factory :) I didn't really have anywhere to mount it, and I didn't want to get an a-pillar mount quite yet soo... I decided to retrofit it into the cluster. It's not perfect, but it gets the job done.
    It was a pain in the ass to fit it in there, but I made it work.. I wish I could have used the stock needle, but they're different sizes.
    Midwest Spec E30 #64
    https://www.facebook.com/thestickergarage
  • mbonder
    • 2255
    Looks pretty darn good, nice work!
    • dnick
      • Apr 2011
      • 1377
      i like it! MIGHT have to do this myself.. mines not working i dont think lol
        • 37833
        It actually does look like a clean install, post a pic with it back in the car.
        Would have been easier to buy the $5 sensor though. :)
        Grover Beach, California
        BimmerHeads.com
        • Jszy25
          • 352
          I really like that a lot. Good idea and execution.
          91' 318is - OBDI M52/ZF swap w/ S50 cams
          • jeffmn8
            • Jul 2010
            • 217
            Thanks guys! I'll get another picture of it in the car a little later. Yes, it would have been easier to just get the right sender, but knowing exactly where my temps are at is nice :D
            • Jszy25
              • 352
              But then you'd still be in the dark with what your actual temps are.
              I really want to do this to my cluster now.
              • FreedS4
                • 752
                Nicely done! I've got an Auto Meter in the dash, in a two gauge faceplate that replaces the radio. However, having two water temp gauges in the car is unnecessary, as the stock one is almost worthless. More info on what you did to make this work, so I can get rid of the stock one and use the open spot for another gauge (oil temp?). Thanks!
                Chris
                • Jand3rson
                  • 37587
                  I like it. Just paint your needles red, and do that one the same color.
                  • E30_Doc
                    • Jun 2011
                    • 49
                    Originally posted by janderson
                    i like it. Just paint your needles red, and do that one the same color.
                    • cale
                      • Oct 2005
                      • 2331
                      Neg, I say get a new gauge face printed to clean it up a bit. Then paint the needle white and the oval portions of the need black like the other needles are.
                      • kalib0y
                        • Dec 2004
                        • 3620
                        looks very clean. When I first glanced at the picture I just thought it was a stock cluster
                        95 7.1L 16V E36 M3
                        Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                        LIKE my Facebook Page! CLICK HERE
                          • 34844
                          It looks pretty good. Too bad it's degrees F. seems a bit goofy in a car that's all metric. :p
                          not really.. 1/4 = 70c, 1/2 = 85c, 3/4 = 100c
                          there's nothing wrong with a functioning E30 temp gauge. But BMW started doing dumb things like dampened gauges for the stupid people buying modern cars. The E46 only reads cold, warm, and hot. You can't see any fluctuations in temp at all. It can be programmed out though..
                          • Jszy25
                            • 352
                            You're probably right, I think I'm jaded by the e36 dummy temp gauge.
                            • jeffmn8
                              • Jul 2010
                              • 217
                              Thanks everyone. I don't think I'll be painting the needles though... This car is bound to be a track rat within the next year or two if I don't sell it.
                              Chris
                              Here's the quick and dirty summary..
                              -Remove the stock temp gauge
                              -Cut the bezel off the new gauge and remove the gauge from the shell.
                              -Cut the three studs off the back so that they were flush with the plastic frame (so that it's the right height)
                              -Remove the needle and face plate.
                              -Solder wire leads to the upper part of where the studs are
                              -Remove the face plate off the stock gauge
                              -Drill holes in the stock gauge face plate to match the aftermarket ones
                              -Put the stock faceplate under the aftermarket one and put the two screws back in (stock is slightly larger than the aftermarket
                              -Reinstall needle and calibrate gauge
                              -Install gauge into cluster.. I ended up taping the edge of the faceplate on the inside to keep it from moving. Once you screw everything back together, it'll stay nice and snug in there.
