Ground Locations? No Start, No Crank:(
  • rhE-30
    • 498
    So I thought i was gonna be finished up with my swap this weekend but I got a no start, no crank situation which has me feeling a little down. I have triple checked the wiring, the relays are getting power, the ground that splits off the harness is attached to the strut tower, the engine mount ground is connected to the chasis, starter is good, engines spins with little effort via crank bolt. So when I turn the key nothing just dash light and idle air control humming. The only other thing i could think of that is wrong is I have an extra ground strap that I found laying around that is 6 inches long, I'm not sure if it's from the donor car though.
    The engine is an M50tu out of a 93 325is automatic. My car is a 1985 318is.
  • DesertBMW
    • Aug 2011
    • 1042
    You forgot to hook up a starter, small 8mm nut.
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Wait, an early 318iS?
      • rhE-30
        • 498
        yellow/black wire is hooked up.
        85 318i no 's'
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          You said it was an iS in the OP.
          • rhE-30
            • 498
            Dang Farbin does anybody have more post than you?
            I took the starter over to auto zone, it failed spectaculary, not even a flinch.
