What headers work best?
  • bonham123
    • 35
    Do obdII bolt up to the e30 stock tubes? Also will obdII bolt up to a non vanos motor?
    • FredK
      • 14764
      No, OBD-II manifolds do not bolt up to the E30 stock tubes.
      They will bolt up to a non vanos motor.
        • 34847
        neither will OBDI, right?
        • N2MYE30
          • Oct 2007
          • 5536
          Right. I had it all redone when from downtube on.
          OBDII headers are not the same as OBDI, as far as where the downtube meets the mani, right?
          COTM
          • jrdeamicis
            • Nov 2008
            • 956
            They are exactly the same.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
            • mtlbloodshot
              • Jul 2011
              • 761
              Im so glad to hear that ODB2 Manifolds fit perfectly
              MY BUILD THREAD
              http://www.r3vlimited.com/board/showthread.php?t=235231
              INSTAGRAM : @luchcolaneri
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                So, OBDII manifolds, to e36 midsection clears without modification to the midsection?
                • SwiftE30
                  • Jun 2010
                  • 998
                  so from what i gather... OBDII > OBDI manifolds?
                  i have OBDII manifolds right now (nothing after that, i havent finished my exhaust yet) and was planning on picking up a set of OBDI manifolds with the midpipes form the JY.
                  Should i stick with the OBDII and weld the holes or pick up the OBDI's?
                  1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                  • Leo_328i
                    • 226
                    OBD2 manifolds are better, they are made of stainless steel which is a lot lighter and the casting process was improved so the internal tubing is much smoother from factory.
                    Weld up the holes or plug them with the appropriate sized bolt!
                    Leo.
                    E30 318iS, E36 328i
                    • mtlbloodshot
                      • Jul 2011
                      • 761
                      When do you plan on putting your exhaust on? I need ideas so I can do mine!!!
                      MY BUILD THREAD
                      • hwy84
                        • Aug 2009
                        • 190
                        No. The midsection WILL interfere with the sway bar/subframe. However, I solved the clearance issue with a smooth 19 oz finish hammer and some well placed smacks on the downpipe. Not hard, and didn't impact the pipe's roundness too badly. Not the most elegant solution, and likely temporary, but works fine.
                        The only way I was able to get the midsection on to the manifolds was to lift the exhaust side of the engine with the hoist, get the midsection in place, get the nuts started on the studs, and then lower the whole f-er into the bay. Pretty easy, but would have been impossible without lifting the motor, or removing the studs and using bolts instead.
                        Current:
                        1991 325i Sedan - S50 Swap
                        1988 325i Cabrio
                        Past:
                        1991 M3
                        1991 318is
                        1985 325e
