California Bar Questions
  • ian e30 318is
    • Mar 2007
    • 1809
    I have an appointment friday and I just had a few questions:
    1. Do I need to put in my red label dme or can I pass with a silver label with a delete chip?
    2. Do I need to attach my coolant reservoir somehow? I have a 318is and there is no bracket.
    3. Do I need another fan besides the stock auxilary (Fan delete and haven't hooked up my puller yet)
    Motor is stock OBD-I S50, stock exhaust manifolds, stock e36 cats, and stock intake (for the test)
    Any other advice let me know. Thank you and wish me luck!
    -Ian
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • Rsully70sev
    • 2391
    Sounds good to me. Good luck man, I heard some refs are assholes and nit pick, I heard others are way more chill.
      • 37833
      I don't think they'll be concerned with any of the thing you're worried about.
      Sounds like you've got the important stuff taken care of, let us know how it goes.
      Grover Beach, California
      BimmerHeads.com
      • mammoth_e30
        • Nov 2009
        • 818
        +1 you should be good to go from all the information I have read on their website
        • CHIF8008
          • 3447
          Can you post the cost and location of the BAR inspection place please
          -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
          -The Beauty in the Tragedy-
          MECHANIC SMASH!!- (you all know you do it)
          Got Drop?? ;-)
          But of course
          E30s are know to be notoriously really really really ridiculously good looking
          • mammoth_e30
            • Nov 2009
            • 818
            check it out, give them a call!
            • kermugit
              • 88
              Go to southwestern college, mike the ref there is totally cool. If you have all stock smog hooked up you should be gold. Also make sure your cats are nice and hot. Make sure you have an 88c thermostat, I failed first time because I forgot about my 80c stat when I did my swap.
              Many soldiers go unknown.... You will never be forgotten SSG. Matt Mauphin, SPC. Juan S. Restrepo and all past and to come
              • drummerchubbs
                • 512
                Thanks kermugit, I didn't think the t-stat would keep you from passing. Thanks for informing me!
                SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
                • ian e30 318is
                  • Mar 2007
                  • 1809
                  Thanks for the info. Ok so I couldnt get the stock e36 air box to fit. Now I'm running a k&n cone universal filter. I hope the guy Is cool. If not what do others do for a stock air box. Mine is hitting the abs. Also why won't I pass with an 80 degree thermostat? I have one installed with my fan delete kit.
                  Instagram:
                  LS Build Thread:
                  • kermugit
                    • 88
                    OBD1 has the intake air temp in the intake manifold, you don't need your air box. I had a k&n filter on the end of my maf, was not a problem. Also the 80c is too cool for the engine temp and runs rich due to the dme reading lower than 190 f with 80c thermostat. I fail because of this part. My cats could not get hot enough to convert the extra HC levels from the richer running engine with the 80c thermostat.
                    • ian e30 318is
                      • Mar 2007
                      • 1809
                      Ok thank you! I'll just beat the shit out of it before I go. We will see! I'll let you guys know how it goes.
                      Instagram:
                      LS Build Thread:
                      • kermugit
                        • 88
                        A couple of BAR failures here was due to the dme running on warm up mode because of the cooler thermostat. Good luck!
                        • kermugit
                          • 88
                          Drummerchubbs, glad I could help.
                          • ian e30 318is
                            • Mar 2007
                            • 1809
                            Guess what...my bitch is legal!!! I breezed through the Miramar station! Very friendly as well
                            Instagram:
                            LS Build Thread:
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              Nice!
                              Originally posted by 325Projectz
                              don't listen to the diagram... listen to mr. swiss.
                              :nice:
