here is the scenario:
culprit: ZF 5spd trans w/ 323 euro TOB, brand new clutch kit
issues: 1st and reverse gears cannot be selected. when sitting at a stop light the only way to get the car going is starting in 2nd gear. you can select 1st or reverse gears if the car is shut off and only when its shut off, otherwise extremely difficult. the person working on my swap car has stated in his dealings with the transmission (pulled it several times to diagnose prior issues i posted about here regarding the TOB and slave cyl) he has examined the shift fork several times and didnt see any damage or anything out of the ordinary. but, his only two conclusions are that there is still an issue with the clutch setup or that something is indeed wrong with the shifter fork.
i told him after getting the above information from him that i would regurgitate it on here and pick some knowledgeable brains on here for any possible answers/solutions.
what do you guys think? this is that last major mechanical hurdle that they seem to be running into
edit: i guess i should have popped this in the drivetrain/transmission section, apologies!
