ZF trans issues- 1st and Reverse
  • BADCLOWN
    • 399
    #31
    Originally posted by Mr.SWISS
    Fixed?
    i had a super busy second half of the week/weekend and this week im busy as well with interviews/etc.
    checking on whatever progress may have been made is always a backburner item, especially recently. as soon as i find anything out ill definitely report back here to potentially pick your alls brains some more.
    clearly, as im sure you all have figured out, ill need any help i can acquire. :(
    FOR SALE: diamantschwarz metallic 1991 m52 e30
    silbergrau metallic 2004 330i ZHP
    • Adrian_Visser
      • Jun 2006
      • 2823
      #32
      FYI the e36M and e36 328i slaves are not identical. There was a lengthy thread about this in the Bfc FI section where guys were having problems with clutchnet clutches not disengaging properly. It came down to the difference in travel/internal diameter between e36M and e36 328i slave cylinders. The 328i is 20.64mm ID and the m3 is 22.2mm ID, the smaller slave will increase pedal effort but also increase travel.
      '89 Alpine S52 with goodies
      • BADCLOWN
        • 399
        #33
        so the 328i slave will give you the release point right off the floor vs. the e36M slave giving you the halfway point release?
        • Mr.SWISS
          • Nov 2005
          • 1251
          #34
          Hmm... They list as interchange at most parts sources how interesting..... maybe why my pedal feels to fuh raze. :p
          Originally posted by 325Projectz
          don't listen to the diagram... listen to mr. swiss.
          :nice:
          • BADCLOWN
            • 399
            #35
            looks like the last of any suggestions or ideas have been exhausted as of the phone conversation i had today at the ass end of my work day. next step:
            remove trans, install slave/TOB with the PNs on page #1 of this thread per suggestions, throw a new fork in there, and do the detents. if this doesnt solve the issues i swear im out of patience. should know by tuesday what happens.
            • 328ijunkie
              • May 2007
              • 3961
              #36
              I've run 20 different crazy clutch/trans/fw setups as has wangan On here without any issues. Just have to make sure
              You match certain things up right and keep
              The stack up height the same
              Check Us out on Facebook
              Full Product Line Tuning
              • BADCLOWN
                • 399
                #37
                ill have to see how it plays out early next week, through researching (and your alls knowledge in this thread) ive realized that it trans setups can be a true puzzle in regards to mixing and matching parts.
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  #38
                  e36 M3 slave p/n: 21521116360 (22.2mm bore)
                  e36 328i slave p/n: 21521159045 (20.64mm bore)
                  The 328 slave will cause increased pedal effort but longer travel, thus the pedal should release higher up from the floor.
                  • Wanganstyle
                    • 2828
                    #39
                    try a 6mt swap. LOL - THAT is a puzzle if you want to get it perfect... I have a 2010 turbo clutch bolted to my 1985 euro M20 with a 2006 6mt transmission.
                    If the slave is from any ZF, and the clutch is a new setup from any g260/ZF5 then it will work. Dave can send you in a box a proven matching clutch fork, TOB, clip, slave to go with your ZF5 if your local shop just cant get it right.
                    a S52 clutch is actually directly usable in a G420 6 speed also. and a M30/s38 5 or 6 speed. Friction disc just has to match the gearbox splines.
                    228/240mm clutch is the most common BMW item; historic range is from 1970's untill......now.
                    • BADCLOWN
                      • 399
                      #40
                      update: seems as though the two PNs for the slave/TOB mixed with a new fork (done in the event there was some minute damage to it causing any shifting issues) got everything working correctly and shifting smoothly.
                      just a couple more things to button up and the car should be returned to me.
                      thank you guys for your insight/knowledge regarding the situation. it was tough hearing/receiving contradictory information saying what worked and didnt work in various threads. much appreciation to you all. :up:
                      • Mr.SWISS
                        • Nov 2005
                        • 1251
                        #41
                        You're gonna love the M52/ZF combo in the E30. 200hp and up and it's like a totally different car(power reminds me of my old 964). Get a DSSR and a GOOD shift kit! The pull in low gears is retarded and with the short shift kit I find myself skipping gears all day shifting from 1st to 5th and it just picks up and cruises 40 like wut. Want some more? 5th gear pull is incredible man. It's a hoot, enjoy!
                        :nice:
                        • BADCLOWN
                          • 399
                          #42
                          interesting insight.
                          to make a long story short: more than likely the car is going up for sale shortly after i get it back. i have a couple more things i need to add on to the car but for sale ads are inevitable at this point. if i do keep it i did plan on getting a shift kit and putting a different rear in the car.
